Old 03-02-2006, 11:18 PM   #1 (permalink)
Default pls help dvd rom fails 2 read dvds
i have a NEC DV-5700A DVD-ROM.
i recently formatted my computer and installed windows xp
since then dvd-rom fails to recognise dvds with UDF file format.
dvds having CDFS file format such as given by DIGIT work properly.
ERROR MESSAGE:WINDOWS HAS FAILED TO RECOGNISE THE FILE FORMAT
OF THE DEVICE.
PLEASE HELP....
I AM NOT ABLE TO WATCH ANY OF MY MOVIES WHICH ARE ON DVDS....
ZEUSS is offline
Old 04-02-2006, 12:16 AM   #2 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Please try updating the drivers for ur DVD drive via the manufacturers website.Sumtimes, the CD ROM also fails to recognise its own file system wich is CDFS,so by jus updating the drivers/files solves the problem. are u using WIN XP with SP1 or SP2 ???
cheers n e-peace....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 06-02-2006, 12:02 AM   #3 (permalink)
thnx for ur reply
i m using XP(build 2600)with sp2
i m not able 2 find drivers for the rom
if u can pls search for me and send me the link
pls pls do a favor for a friend
thnx in advance
ZEUSS is offline
Old 10-02-2006, 10:51 PM   #4 (permalink)
I too have problem of TOSHIBA DVD-Rom SD-M1712. It reads Digit DVD in Windows98SE but fails in Windows Xp-SP2.
Error message is:
"Windows cannot read from this disk. The disk might be corrupted, or it could be using a format that is not compitable with Windows"
Any help?
maliwalrs is offline
Old 11-02-2006, 12:04 AM   #5 (permalink)
Default Help DVD ROM not reading any DVD
Help me
my DVD Drive is not reading Any DVD It gives the error message
Wndows can not read from the disk The disk may be corrupted or the format is not compatible for windows
I recently formated my HDD And reinstalled my windows
duelmaster is offline
Old 11-02-2006, 09:30 AM   #6 (permalink)
The Hardware Labs
mohit's Avatar
similar thread going on HERE
Please search the forum before posting very common queries.
mohit is offline
Old 26-02-2006, 03:53 PM   #7 (permalink)
guys all techies
pls help.............
i m in desperate situation
my friend just brought a lotr collectors edition dvd pack
the dvds fail to read.....
pls help all u lotr fans
ZEUSS is offline
