Old 03-02-2006, 04:27 PM   #1 (permalink)
Default Installin PCI video card in Intel 865GBF..
Hello frens,
I have brought an second hand Ge force fx 5200 PCI video card for to be used in my P4 as well as P3 system which has no AGP slot. So how to install the PCI card in my P4 system, i have inserted the PCI slot into the pci local bus and and the monitort pin in to the card but cant get an display.
I have Intel 865GBF , P4 2.8 ghz, 2 Gb ram DDR 400 mhz ram and an 80 gb hard disk.
Plz tell me briefly......
GANESH
ganesh_2218 is offline
Old 03-02-2006, 06:59 PM   #2 (permalink)
the 865GBF has agp slot and also onboard intel extreme graphics. You have to change the setting in the bios. You have 2 choices i think, AGP or PCI. choose PCI.
hotdogXP is offline
Old 03-02-2006, 07:17 PM   #3 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
hotdogXP
Yup, absolutely rite bro, ganesh, in ur BIOS jus change the Video mode from AGP to PCI
cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
