Old 02-02-2006, 02:38 PM   #1 (permalink)
KKK
Default HELLLLLLP VERY URGENT!!!!! PLEASE REPLY SOON!!!
I BOUGHT THE ANTEC SILVER COMPOUND....AND I BOUGHT THE AMD ATHLON64 PROCESSOR!!
NOT SHOULD I SCRAP OF THE THERMAL PAD AT THE BOTTOM OF THE HEATSINK WHICH IS PROVIDED AND APPLY THE ANTEC SILVER COMPOUND OR.....SHOULD I APPLY THE SILVER COMPOUND DIRECTLY OVER THE THERMAL PAD??????
PLEASE REPLY SOON!!
AND THANKS TO ALL IN ADVANCE!!
KKK is offline
Old 03-02-2006, 01:58 AM   #2 (permalink)
Wire muncher!
infra_red_dude's Avatar
you don't put in the silver compound over the thermal pad. you either haf the thermal pad or the thermal compound there! never heard of using both simultaneously!
infra_red_dude is offline
Old 03-02-2006, 01:14 PM   #3 (permalink)
SABER RIDER
maverickrohan's Avatar
u can scrap of the thermal strip from the bottom of the heatsink.......
Find out Which is The Best Video Codec?....And how to encode video the right way..!!----->>>>> http://www.thinkdigit.com/forum/showthread.php?t=3908
maverickrohan is offline
Old 13-02-2006, 08:14 PM   #4 (permalink)
Default Thermal
yes scrap of the thermal pad and clean the base of the heatsink with alchol or spirit and then apply......the antec thermal compound....otherwiswe it will be of no use at all......
zuala77 is offline
Old 14-02-2006, 08:19 AM   #5 (permalink)
Learner
Kniwor's Avatar
Default Re: HELLLLLLP VERY URGENT!!!!! PLEASE REPLY SOON!!!
PLEASE REPLY SOON!!
interesting question....
but i dont expect u to ask this question, not specially you.....
because the answer is driven by simple logic, the basic conductivity law, u got antec because it had better conductivity, now if u apply it on the pad what use it is, the heat will have to apss through the pad which has lower conductivity, so basically it will not serve any purpose, but only make it worse,
now Why worse???
because whatever is conductivity of these compounds it is less than the heatsink and we use them to fill the air between procy and heatsink, because the contact cannot be even, so the less we use the better it is, as long as we fill the gap.... and there is no air...
Kniwor is offline
Old 16-02-2006, 08:58 PM   #6 (permalink)
Use a little bit of basic knowledge we get from High school physics , air is an insulator and will not allow heat transfer , anything other than air or which does not contain air (like a sponge or a foam pad or a pillow or blanket which traps air) is a conductor. So if u have even a tiny bubble of air the conductivity drops in that spot. Antec silvev compound is a gr8 conductor as it contains silver which is an excellent conductor of heat and electricity ( So take care u wipe any excess).
Huzefa is offline
