Originally Posted by mayurhastak
if u dont use DVDs for a long time, evntually the combo doesnt read the DVDs after some time
What nonsense? Its nothing like that...Just that with prolonged periods of inactivity dust & moisture accumulates on the drive lens which needs removal. But after that drive continues to read DVDs normally...
In this case, the problem seems to be something else...Try cleaning the lens...Also see if all the cable connections are intact...Also check whether the drivers of the drive are not corrupted & hav been updated accordingly...
HK
