Old 01-02-2006, 11:51 AM   #1 (permalink)
Chillum Baba
a_medico's Avatar
Default Weird Desktop - please help
i am posting the screenshot along with the queries
model - dell 700m centrino
is this a windows xp problem or display driver error? or just some windows settings which i am not aware of?
a_medico is offline
Old 01-02-2006, 02:08 PM   #2 (permalink)
1. Go to My Computer. Select Tools menu->Folder Options. First option in General tab is to be changed from "Show common tasks in folder" to "Use Windows Classic Folders"
2. Right-click on Taskbar and select Properties. Here, the last option "Hide inactive icons" is to be unchecked. Also, it is possible that you may have set certain software to not show their icons. For eg, battery may be set in Control Panel (Power Options I think)
3. Right-click on Taskbar and uncheck "Lock the taskbars"... If this is not the problem, not sure what to do.
Arun
sakumar79 is offline
Old 01-02-2006, 02:59 PM   #3 (permalink)
Chillum Baba
a_medico's Avatar
sigh* .... already tried it all...aint working...problem persists...
thanks for the reply..really appreciate
a_medico is offline
