Originally Posted by vishnu25521
if u ve ATX SMPS then check by short the green and black wire, if smps fan starts then its ok....after that also there is prob then check the voltage by the meter. with four wire that +5v, +12v are coming or not if not then smps needs to be changed....
Hey need not to change SMPS, It could be repaired for max of 100-150 Rs
I had repaired my Spms once, but in that case voltages were alrite, prblm was with Capaciter which somehow Got "LEAKY"
Dont take HASTE decisions?
Give Reparing A thought
