Old 29-01-2006, 06:35 PM   #1 (permalink)
Default EMBR missing
whenever i boot my system i get an error
EMBR missing!!
i have to insert a bootable cd and boot the system..
any solutions..
deepak_vsoni is offline
Old 29-01-2006, 06:43 PM   #2 (permalink)
dIgItaL_BrAt's Avatar
If u're using XP,boot from the XP cd and in the recovery mode run the 'FIXMBR' command.
dIgItaL_BrAt is offline
Old 03-02-2006, 06:53 PM   #3 (permalink)
Default not working
digital_brat the solution you gave is not working... any other solution
Old 03-02-2006, 07:06 PM   #4 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
why dont u just do a repair install
vijay_7287 is offline
