Old 28-01-2006, 06:49 PM   #1 (permalink)
UBERGEEK
PCWORM's Avatar
Default A GREAT SOUNDCARD HUNT
WELL THIS IS MY FIRST TOPIC AFTER REGISTERING WITH DIGIT FORUM.......
I HAVE ALREADY PURCHASED AN AMD PLATFORMED PC, BUT NOW I AM IN SEARCH OF A GREAT AUDIO CARD TO COMPLETE MY HOME THEATER SETUP......
I WANTED TO KNOW WHICH SOUNDCARD WILL OFFER GREAT CLARITY AND SUPPORT ALL THE SPANKING NEW
TECHNOLOGIES OF HOME THEATER SETUPS......WELL, PRICE IS NOT THE BAR....
THANK YOU
PCWORM is offline
Old 28-01-2006, 07:10 PM   #2 (permalink)
gxsaurav
Posts: n/a
Look for sound blaster X-Fi extreme music, thats the cheapest card in XFi series but it has all the same feature & power of the high end X-Fi cards, except for the live Drive which u will hardly need ever
other options are Creative Audigy 4 ZS or Audigy 2 Value
Old 28-01-2006, 09:10 PM   #3 (permalink)
phatratt's Avatar
with price barred and u want a home theatre setup then get X-Fi elite pro.
phatratt is offline
Old 29-01-2006, 05:46 PM   #4 (permalink)
sagar_coolx's Avatar
whats rong with the onboard card?
sagar_coolx is offline
Old 29-01-2006, 05:59 PM   #5 (permalink)
 Macboy
goobimama's Avatar
Try sticking in a high end home theatre system into onboard sound and see the results....
Good soundcards have features like high SNR value, 24 bit audio, DD and DTS decoding, among others. I find a noticable difference in my logitech z5500 speakers (using 915 onboard audio against creative Live! 5.1 AGAINST CREATIVE AUDIGY 2 ZS)
@ pcworm: The X-Fi series will give you best performance if price is no bar. But the Audigy 2/4 also makes for a very good soundcard.
I'm like a bird... :)
goobimama is offline
Old 29-01-2006, 07:03 PM   #6 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
another vote X-fi
vijay_7287 is offline
Old 29-01-2006, 08:11 PM   #7 (permalink)
i m using Audigy 2 ZS..
and believe me it gives me whatever i want.. 6 K for that card is good enought.. it has all features.
but if u have loads of cash.. then x-fi.. i have no idea about its current rate..
I\'M BACK
khandu is offline
