Old 28-01-2006, 11:11 AM   #1 (permalink)
Default What is CAS Latency in RAM
I wanted to get a 512 MB DDR 400Mhz RAM and was going through a few online shopping sites, they have specified a parameter in the specs of the RAM called "CAS Latency" , the value varying from 2.5 to 3.5 for different RAMs of the same make and Mhz.
Is it related to any performance factor of the RAM and should I take this parameter into consideration when I want to buy it. I already have a 512MB 400Mhz installed in my system and in the BIOS it says the CAS Latency of this RAM is 3.0, should I get the additional 512MB also with the same value to work them in Dual channel config.
hotdogXP is offline
Old 28-01-2006, 03:08 PM   #2 (permalink)
phatratt's Avatar
CAS stands for Column Access Strobe.THe data is stored in columns and accessed in nanoseconds which varies from 2 to 3.5.
Googled it and got some info
http://www.dewassoc.com/performance/...as_latency.htm
phatratt is offline
