Originally Posted by chirag
Woofer and Speakers. I think this have to be the cause of problem. I also had this same problem. I placed my woofer else where and my monitor was working fine as ususal. Speakers u can place besides montior also. No prob with speakers. Only Woofer.
Tell me if that helped.
Yes what Chirag say is true.
Besides, which monitor model do you have. Eg: HCM581M, please tell.
Have you installed the latest graphics drivers and which OS are you using.
U should be able to configure the graphics drivers and set it to atleast 85 Hz. Your monitor supports it.
Now is this also does not solve your problem, and if your monitor is still on warranty return it to HCL , they will give you a new one.
Besides 15"HCL monitors does not have this sort of problem at all, infact non of the HCL monitors have any problems for that matter.
The contrast level and brightness are simply very good in HCL monitors.
I don't understand how did you end up getting such problem. I strongly recommend you to return your monitor to HCL for a replacement if it is still on warranty.
