Old 26-01-2006, 03:23 PM   #1 (permalink)
Too hot for this forum.
Default AGP 4X/8X confusion
hi.
wanted to know if an AGP 8X card will run in an AGP 4X slot.
Also any good cards of the 4X type.
reply asap pls.
s_aerin is offline
Old 26-01-2006, 05:24 PM   #2 (permalink)
phatratt's Avatar
yup u can chuck an agp8x card on a 4x slot but it will work in 4x mode
phatratt is offline
Old 27-01-2006, 05:47 PM   #3 (permalink)
thnx.but are u sure?becoz the shopowners here are quite difficult to deal with.once they sell me the card,they will refuse to take back the card if it doesnot run on my pc.
pls confirm and reply.
thnx again,in advance.
s_aerin is offline
Old 28-01-2006, 03:13 PM   #4 (permalink)
phatratt's Avatar
Go through the mobo manual and check if it has given any list of graphic card.As not all cards(8x)will work in 4x mode.so double check before buying a graphic card.
if u r still confused just go through this links
http://www.neoseeker.com/Hardware/faqs/kb/10,63.html
http://www.faqfarm.com/Q/Will_an_8x_..._a_4x_AGP_slot
phatratt is offline
Old 29-01-2006, 04:14 PM   #5 (permalink)
i bought an nvidia geforce card for Rs.1900.128 MB,AGP 8X and it is running.thnx for help.
s_aerin is offline
Old 16-02-2007, 02:52 PM   #6 (permalink)
Default Re: AGP 4X/8X confusion
hey all. got a fx 5200 today.
Life's too short.Why use Dialup?
s_aerin is offline
Old 17-02-2007, 12:28 PM   #7 (permalink)
Question Re: AGP 4X/8X confusion
Check this and reply
mPGA478
thanks
mdnath is offline
