Originally Posted by a_medico
ok... heres a short note ... might be help to some of you
got 300 GB IDE Seagate Baracuda (Rs 6200) + External USB Casing Rs 2500
got Lite on 16x internal dvd burner 2500 + External USB casing Rs 2500
Both are working fine with my laptop. Have burnt almost 45 dvds in 2 days on the writer ... not a single dvd gave problem. all workin fine.
each dvd took less than 9 minutes which i think is amazing speed for a external writer.
there are some issues with external casing especially if u buy the cheap Rs800 ones. they can burn only cds while give error while burning dvds. so its better to invest in the costly(Rs 2500) ones. its still much cheaper than buying a proper external dvd burner which costs around Rs 11K
hope this helps.
i dont think those are issues with the cheap ones.... here is what i think is the reason...
some people purchsed USB 1.1 casings and used them as external drives... not it worked fine while writing a CD because a CD typically requires less data transfer speed while writing and usb 1.1 served the purpose.... but a dvd requires more than that and USB 2.0 is required....
so basically it's not a problem with case being cheap or costly....
now since all costly ones come USB 2.0 there are no issues
