Old 23-01-2006, 03:23 PM   #1 (permalink)
Default 80GB Hard disk problem
i cannot configure my 80GB harddisk in my BIOS. Whenever i gave auto configuration, it gets stuck!! But it was working fine for my old 40Gb.
please help.
harikesh is offline
Old 23-01-2006, 04:56 PM   #2 (permalink)
Geforce's Avatar
Please list your computer configuration.
Your BIOS may have a limit and you would need to update it.
Some harddisks come with a jumper setting to limit the size of the harddisk and forcibly detect it.
AMD Athlon64 2800+, MSI K8N Neo3(NForce4), 1GB Kingston DDR400, MSI Geforce 7600GT PCIe, Viewsonic VA702b 17" LCD, Creative SB Live! 5.1, Logitech Z-5300 5.1 THX Speakers, Seagate 200GB SATA HDD
Geforce is offline
Old 23-01-2006, 05:53 PM   #3 (permalink)
I have an old configuration,
Celeron 500Hz
152MB RAM
PC chips M748LMRT
Sis 620 vga graphics
AMIBIOS yr 98
tell me, how can i do this with out upgrading my system.
Since BIOS is the brain, I am really afraid to flash my existing one. Any other alternative??
harikesh is offline
Old 24-01-2006, 12:32 PM   #4 (permalink)
Geforce's Avatar
Before going any further.. you test the 80GB on another system to make sure there is no problem in the drive itself.
here is the link from where you can download new year 2002 bios
http://www.pcchips.com.tw/PCCWeb/Downloads/ProductsDetail_Download.aspx?DetailID=45&DetailNam e=BIOS&DetailDesc=M748LT(V3.x)&MenuID=35&LanID=2
Please make sure the model number matches your motherboard.
(I take no guarantee for this)
Unfortunately this is a BIOS limitation only and no other alternative apart from changing the motherboard iteself (to intel 810i).
SO there is no option but to flash the BIOS.
Read the instructions on the website carefully.
Geforce is offline
Old 25-01-2006, 08:55 PM   #5 (permalink)
Hi,
It is not a problem at all. First of all very whether your mother board support 80 GB hard disk. It it is so. Use Acronis Disk Director Suite 9.0 or Partition Magic 8.05. U can easily Handle ur hard disk with these softwares.
Ramesh.
Ram1959 is offline
Old 30-01-2006, 12:58 PM   #6 (permalink)
Geforce's Avatar
Ramesh.
To use any of these software first the Hard disk should be detected in BIOS and system should BOOT i think. Detection of the Hard disk is the main problem. Maybe the motherboard doesn't support 80GB, thats why the BIOS update is necessary (with caution!).
Geforce is offline
