Old 22-01-2006, 05:18 PM   #1 (permalink)
Default MONITOR PROBLEM( in 17'')
Recently I have installed "SUSE 10"........but after the installation ,I could not able to get the dekstop it displays a message that frequency is more
than the operating frequency in the case of 17''-inch monitor ... and when
I replaced it by 15''-inch then , it is working properly.........
so what should I do ??? PLEASE HELP ME OUT
nittn_only_4u1 is offline
Old 22-01-2006, 09:07 PM   #2 (permalink)
phatratt's Avatar
maybe the resolution and the refresh rate is set tooo high try to decrese the resolution to 1024*768@75hz.I don't know how to do it in suse linux,i believe it has to be done before booting process in console mode(which looks like DOS mode)
phatratt is offline
Old 23-01-2006, 06:12 PM   #3 (permalink)
Default Re: MONITOR PROBLEM( in 17'')
odd
wich 15 adn 17" monitors u have?.. either u have a very very gud 15"monitor and a crap 17" or soemthing wrong with ur settings.
countrock is offline
