Old 21-01-2006, 09:40 PM   #1 (permalink)
Default virtual memory 2 low
my pc is p4,2.8ghz,80 gb hdd,256 ddr ram,845 onboard graphic card
no extra graphic card installed.but when i was playing nfs mw its shows
virtual memory too low.i had covered 3 to 4 stage and afterwards it
minimizes to destop after a splash screen.even the graphic where ok.
can anyone suggest me some method to solve this problem.as pc is of 80 gb
i have partioned my hdd to four drvies and have allocated 950 mb inital size in virtyal memory and maximum size 1500 mb.but it doesnt help.even i
changed video configuration to 128 mb which was 64 mb.can increasing
upto 256mb can harm my computer.can increasing frame buffer size help?
samurai is offline
Old 21-01-2006, 10:04 PM   #2 (permalink)
well when u increase the graphics mem from 64 to 128 MB it reduces system RAM, thereby more and more operations and processes are forced to virtual memory, and when the application finds the lack of memory the performance is degraded
U can solve this ny going for a decent AGP graphics card
and if u do wnat to keep onboard graphics as 128MB upgrade mem to 512MB
Techie_Geek is offline
Old 21-01-2006, 10:07 PM   #3 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
its a case of insuffiecient RAM
for NFS:MW 512mb is a must for smooth play
try gettin rid of all runnin applications and maybe a few unnessary services also
vijay_7287 is offline
Old 22-01-2006, 12:36 AM   #4 (permalink)
my computer->properties->advanced->performance->Advanced->VIrutal Memory -> Change
Select teh drive and increase the maxiumum size of the pagefile
A64 3200 winnie + 512*2 KVR 2.5-3-3-6 2T + MSI K8N SLI platinum - Creative SB Live! 7.1 + Leadtek PX6600GT 550/1125 + 160 GB Seagate N.C.Q. + 320 GB WD + LG 17" CRT
3Dmark05 - 4008 3Dmark03 - 8,983
Ringwraith is offline
