Old 21-01-2006, 09:01 PM   #1 (permalink)
Default The choice of UPS
Acording to my needs about 400watts compatible , UPS requirements
I found the following two models
PC Smart-UPS 750VA USB & Serial 230V has Rs 8525/-
output Connections
(6) IEC 320 C13
(2) IEC Jumpers
whereas the
APC BACK-UPS ES 650VA 230V INDIA has Rs3200/-
(1) India 2/3-pin 6A (Surge Protection)
(3) India 2/3-pin 6A (Battery Backup)
So how do I use 3pin plugs on IEC connectors ??
Please suggest and help
Also do reccommend any other good UPS 650-700 VA and the price
Techie_Geek is offline
Old 22-01-2006, 08:19 AM   #2 (permalink)
get d Powercom 1Kva model.. it has 3pin connectors..! its ~4k..
delhibhai1000 is offline
Old 22-01-2006, 02:43 PM   #3 (permalink)
simple..
APC
cause
1) Excellent and i mean excellent customer support
2) Good software
3) never given me a problem...
I\'M BACK
khandu is offline
Old 22-01-2006, 03:24 PM   #4 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
same topic here
http://www.thinkdigit.com/forum/view...777a61bb4fcdd8
vijay_7287 is offline
Old 22-01-2006, 06:55 PM   #5 (permalink)
soham's Avatar
yes, APC BackUp UPS is the best for home users .
soham is offline
