Old 21-01-2006, 01:11 PM   #1 (permalink)
Default cd drive refuses to open
hi,
i have a cd writer which about 2 years old it has been working fine but now it refuses to open. it does open but after trying a hundred times. rest it is working fine.
sidcool is offline
Old 21-01-2006, 01:50 PM   #2 (permalink)
The Hardware Labs
mohit's Avatar
maybe the tray mechanism needs to get serviced. take it to the nearest service centre buddy and ask them to service and grease it well.
mohit is offline
Old 21-01-2006, 11:26 PM   #3 (permalink)
sportymaniac
Posts: n/a
Yes it needs to be repaired.I had the same problem.the engineer took 100 bucks to repair that.it will be done within minutes
Old 22-01-2006, 12:07 AM   #4 (permalink)
If u r new to H/w then do not try to open it urself. My friend did that and disturbed the allignment of tray.
BTW which model?
ashnik is offline
Old 23-01-2006, 09:57 AM   #5 (permalink)
BTW which model?
it might be,....no no.....it should be Samsung....???
http://njaan.blogspot.com/ - A Malayalam Blog
pratheesh_prakash is offline
Old 23-01-2006, 12:50 PM   #6 (permalink)
rajesh's Avatar
Get it checked by the an authorised service guy if it is a branded CD writer.
My Blogs
______________________
http://laughlines.rediffblogs.com
http://krrajesh.blogspot.com
rajesh is offline
Old 23-01-2006, 04:31 PM   #7 (permalink)
if u ask me , throw it and buy a dvd riter
sagargv is offline
Old 24-01-2006, 07:21 PM   #8 (permalink)
Netjunkie's Avatar
Is that a Samsung?
If it is, then dump it soon. I have a Samsung CD-RW & faced the same problem.
Visited the service center two times but it still dosent work properly.
Netjunkie is offline
