Old 19-01-2006, 12:16 AM   #1 (permalink)
gxsaurav
Posts: n/a
Default Geforce 7300 GS out now
Nvidia today launched the all new Geforce 7300GS for the mainstream market, for the Sub-$ 100 market, which is something atleast India looks forward to as the market of Sub Rs 5k is the maximum market share
The geforce 7300 GS has 64 bit memory path & only for PCI-E which is kinda bad, but since 7800GS is coming out, it's good already
Clock speed is set to be 550 MHz & Memory speed 1 GHz, depending on the manufacturar u might also see , added turbocache features
Now, atleast i m looking forward to the 7600 series launch
Old 19-01-2006, 12:40 AM   #2 (permalink)
 Macboy
goobimama's Avatar
guess its gonna be better than the 6600 huh? I was right in waiting for a 7xxx series card...
I'm like a bird... :)
goobimama is offline
Old 19-01-2006, 01:15 AM   #3 (permalink)
gxsaurav
Posts: n/a
no way it's gonna be better then 6600, even non ultra, that has more pixel pushing power then 7300GS, this is better then only a 6200 series card, & 6600LE, as i said it is released in the Sub-5K market
better go for 6600 if u can, as both 7300 & 6600 support same features, hardly much difference in games, while performance will be less then 6600 series due to 64 bit memory path, even the purevideo engine is same
for those who are buying new card, for the first time or, wanna upgrade from FX5200 this is a good option, stick to Geforce 6200 if u already have one
