Old 18-01-2006, 10:00 PM   #1 (permalink)
Default LAN using USB ??
Can 2 computers be connected using a USB cable ??
P4 2.4 GHz Prescott;768 MB RAM;Seagate 80 GB PATA & 160 GB SATA;Creative Inspire 5200;ViewSonic E71f;256 MB Leadtek A6600TD;Logitech MX518;Microsoft Natural Ergonomic 4000
cyberzook is offline
Old 19-01-2006, 11:18 AM   #2 (permalink)
Yes.. U can .. there is a cable which does this job.. its called as "USB DirectLink Cable"...
mangemayur is offline
Old 19-01-2006, 09:01 PM   #3 (permalink)
I have bought a USB cable..
I have inserted the ends in USB ports of each computer but nothing is auto-detected
Help
Old 20-01-2006, 11:58 AM   #4 (permalink)
have u bought "USB DirectLink Cable" or something else.. i searched on google for this.. and site which sells/make them.. they claim "Its will be auto detected" but there is also a software which comes.. by which u can transfer the data
just to make sure that u have USB Direct link cable only ... this cable is having USB port at both end and in the middle there is some IC... for us it will be a notch sort of thing... u can have a look at
http://www.usbgear.com/link/
http://www.usb-port.com/bf100c.html
Old 20-01-2006, 08:23 PM   #5 (permalink)
dude. that cable just allows data transfer.. and not the work of a LAN cable.. u need the software to be installed on both the PC and running which allows data sharing...
i have that cable.. its a waste.. buy a LAN card for 250 bucks and get a crossover CAT 5 LAN cable and u get direct link..
I\'M BACK
khandu is offline
