Old 18-01-2006, 05:16 PM   #1 (permalink)
Default Help..purchasing a motherboard
hi i am having an intel p4 3 ghz proccessor and i want a new motherboard...my budget is around 6000..... and can i buy a amd board with processor combo for around 6000...please help..
zuala77 is offline
Old 18-01-2006, 05:47 PM   #2 (permalink)
Manchester United
abhijit_reddevil's Avatar
Buy any intel original motherboard based on the 915G chipset. Or you can try to get boards from 3rd party manufacturers like Asus, Gigabyte, MSI, etc. All of them will come below your budget of 6000. On other thoughts, if you up your budget a little (say 500-1000), you can get some boards based on the Intel 945 chipset.
By the way, I do not understand why you want a AMD based board when you have a good intel processor. If at all you want to dump the presscott, then your choices will be something like MSI RS-480M2 or Asus A8N-E or Asus A8N-VM, but in no way you can get the processor and board combo for below 6000. The above mentioned boards alone costs in the range of 4500-5500.
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen:cloud9:
abhijit_reddevil is offline
Old 18-01-2006, 10:10 PM   #3 (permalink)
Go for Intel D101 GGC board for LGA 775 3 GHz processors
P4 2.4 GHz Prescott;768 MB RAM;Seagate 80 GB PATA & 160 GB SATA;Creative Inspire 5200;ViewSonic E71f;256 MB Leadtek A6600TD;Logitech MX518;Microsoft Natural Ergonomic 4000
cyberzook is offline
