Old 18-01-2006, 05:01 PM   #1 (permalink)
Default Ram problem
I am using a 333 ddr ram 512 i,e 256X2 dual channel........ and i keep on getting memory dumping with bsod can it be because of my ram....how do i know that they are compatible.....i have reinstalled my os serveral times..... but no use....should i buy a new ram...without dual...channel..
Please help
zuala77 is offline
Old 19-01-2006, 01:46 AM   #2 (permalink)
The Hardware Labs
mohit's Avatar
For a Dual Channel config. check the following,
1. Both modules are the same capacity (e.g. both are 256MB, or 512MB)
2. Both modules are the same speed (e.g. both are PC2700 or PC3200)
3. Both have the same number of chips and module sides (e.g. both have the
same number of chips on the module, and both are either single-sided or
double-sided).
if u still get blue screens then download memtest86 from www.memtest86.com and make a bootable cd and test each of ur ram sticks one at a time for 3-4 hours and see if u get any errors. if u get errors then get ur ram replaced.
mohit is offline
Old 19-01-2006, 04:13 AM   #3 (permalink)
Learner
Kniwor's Avatar
Did u purchse both the ram sticks together?
How many slots are there in ur mobo, if 4, have u put the memory in same color slots.
are the memory modules identical.
Kniwor is offline
