Old 17-01-2006, 01:28 PM   #1 (permalink)
Manchester United
abhijit_reddevil's Avatar
Default Which SMPS? And prices...
Hi,
I need a new power supply for my new machine (3000+, 512MB RAM, 6800GS). From which brand I should buy and what are the prices? My budget is 1500 to 2000. I am especially looking for a 400W PSU.
Waiting for your early replies.
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen:cloud9:
abhijit_reddevil is offline
Old 17-01-2006, 03:45 PM   #2 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Buy a POWERSAFE/COOLERMASTER 400/450W smps. Really hard to find good branded smps in KOLKATA. Powersafe 400W may cost around 1200-1400.
john_the_ultimate is offline
Old 17-01-2006, 07:46 PM   #3 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
for the 6800gs , it would be better if u have 500w SMPS
given ur budget i suggest, goin for Zebronics
vijay_7287 is offline
Old 18-01-2006, 12:42 AM   #4 (permalink)
TechGuru#1's Avatar
Digitized>> I went for a KPL Powersafe 500 w SMPS!
I have just built a similar config as urself with 3500+
....maybe 500W PSU not needed fully for now,but just used that.....in case of future SLI option.
hence my opinion,u can also use a similar PSU!
TechGuru#1 is offline
Old 18-01-2006, 09:53 AM   #5 (permalink)
Manchester United
@Techguru: How much did your 500W SMPS cost?
As far as I can understand, the Powersafe ones will be my best bet. But availability maybe an issue here. Let's see...
Old 18-01-2006, 11:42 AM   #6 (permalink)
Go far the Vantec ION2 460W model. It provides 30A on the 12v rail which is criteria for deciding which SMPS to buy!
paraman is offline
Old 20-01-2006, 01:00 AM   #7 (permalink)
TechGuru#1's Avatar
@ Digitized : I took a KPL VIP Gaming case G300 along with a KPL Powersafe 500 w SMPS for Rs. 5,300
The Game case cost abt Rs. 3,000,so rest for the PSU!
I dont know, maybe the item> priced a bit on the higher side,HERE!!!
