17-01-2006, 07:34 AM
Gracias Senor
RAM Issue..
My frnd had a Hynix 256MB DDR RAM.. 2 days back his sys created a prob.. like he switched on the computer but only his CPU Runs.. but his monitor didnt turn up.. sterday went to the shop whr he bought (RITCHIE STREET ) and he examined and told the RAM has gone.. and he inserted anothr RAM and the Sys worked fine..
My qn is, is thr any way to repair a RAM.. cos the warranty period expired juz 20 days bac.. TIA
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
17-01-2006, 07:40 AM
If the warranty has expired, I am sorry that theres nothing that can be done, since RAM repairs have been unheard of until now. So buddy, just say bbye to the old RAM & go in for a newer stick...
HK
17-01-2006, 02:48 PM
Learner
I dont think a ram stick can be repaired or manufactured in india.
As os repairing a ram, i have never heard of such a thing ever.
So a new stick is ur only choice
18-01-2006, 02:00 AM
The Hardware Labs
tell him to buy some good branded ram with lifetime warranty like kingston. the warranty is there till the chip is being manufactured. it will cost around 300-400 bucks more but its worth it. i got my kingston ram replaced twice without any probs.
18-01-2006, 04:59 PM
My friend... a computer engineer told me that a ram stick can be repaired only if the fault lies in the capacitors..transistors or n the memory chip....any circuit problems cannot be repaired...but finding a person who can detect the fault and repair it...is difficult...very difficult..in fact ihavent found anyone in 2 years of searching.....so it is better to buy a good ram.......simmtronics, kingston and transcend ram can be trusted....
915g not enough to comfortably play any new game.....even with a 3.0 ghz p4 and 1024mb ram....does anyone know a solution(plz dont tell me to add a graphics card...)
20-01-2006, 07:54 AM
Gracias Senor
Hi mohit.. very impressed reg the lifetime warranty.. is it avail in Chennai Ritchie Street..
thnx for all others in their sugg..
20-01-2006, 11:48 AM
life time warrenty does not mean your lifetime
its the computer's life spam..wich is 5 years only
20-01-2006, 06:12 PM
Learner
this might be true... but where did u get this info, i have always been wondering what lifetime warranty means
20-01-2006, 06:55 PM
The Hardware Labs
lifetime warranty means the time till the chip is in production and its not 5 years. it can be less or more.
21-01-2006, 12:42 PM
Dude.. Anyone with such knowledge of electronics would not be cheap. and also AFAIK complicated and probably expensive equipment will be required to pinpoint the problem, employing such services will be probably more expensive than the ram itself. therefore getting a new RAM is cheaper.
23-01-2006, 11:11 PM
only one thing we can do on our own. if RAM is working slow than its given speed, then just wipe the teeth of the RAM with eraser on both the sides. Actuly u should do it every time u clean the CPU.
Tang
24-01-2006, 07:41 AM
Personally, I feel that Hynix is good enough for regular use. It is stable as far as I have used it. I think the probability of failure is only slightly higher for Hynix and not worth the additional cash that you sink into for Transcend/Kingston, etc. Only if you are into overclocking or need that slightly reduced prob. of failure should you go for Kingston... However, do buy from a reliable source...
Personal experience (my dad's office has 15 computers ranging from old Pentiums to newest Athlons/Semprons) seems to indicate that in most cases, RAM modules will either fail immediately due to defects (in which case your warranty will be valid) or will work quite well for a long period (by the end of which the "lifetime" warranty will prob. be no longer valid).
Arun
26-01-2006, 07:58 AM
Gracias Senor
Is Kingston RAM Avail in Chennai/Ritchie Street ??? and wats the Price of tht for 256 DDR and 512 DDR ??
26-01-2006, 08:51 AM
Learner
Corsair value select is available in kolkata.... cas latency 2.5
