| Forum |
#1 (permalink) |
1. ATX form factor..... with my Asus A8NE board.... and 3000 Amd system 2. More space for drive the better... with atleast space for 4 hard drive 3. nice ventilation with as many fan as possible...like 4 fans 4. It has to be roomy and hassle free 5. Less noise... and good body 6. Stylish... in black mainly but with some touches
Passwords are like underwear... Change them often... |
#2 (permalink) |
SNIST Screamer !!
the ones from kobian and intex are good enough
if u have the bucks go for a gamin cabinet from antec and all specs should be inspected manually coz model numbers are not readily available
http://snistscreamers.blogspot.com/ http://insidevoidmain.blogspot.com/ SNIST-Blog: the Voice of SNIST... http://www.snistblog.com/ |
#3 (permalink) |
okie... but can anyone give me shop names at laminton mumbai as dont know any shops over there which can give me a lot of variety to choose from... from my dealer i get cabinets like PERX iball etc... which i think is not from the company but local brands with label pasted.....
#4 (permalink) |
if ur really tight on budget, then I-box 522 is good for 600-700 bucks. good cooling system
http://www.iballonline.com/product.a...oductname=i522 |
#7 (permalink) | |
The Hardware Labs
#8 (permalink) |
i had only once experience iball cabinet at my friend's place... and i am sorry to say but the quality was nothing les than pathetic.... so i do not want to go for iball model... i am going to look out for gaming cabinet low range from VIP....
#9 (permalink) | ||
Posts: n/a
#11 (permalink) |
so ?
ur entire system performance depends on the cabinet and its cooling capapbilities why would u wanna buy a cheap and bad quality one ? cabinet buys are VERY underestimated ... plz guys .. take care of ur components get a decent cabinet spend a few hundreds more and get a good looking and good quality cabinet .. its one of those one time buys .. like ur monitor ( tho not that expensive ) that u dont change for a long time
No Mercy, No Limits. Oobertech.net - Keeping Knowledge Free |
#12 (permalink) |
the VIP 1122 cabinet is a great buy
it costs about 1,200- 1,400 transparent side panel with a cool led fan...atx and all that is req. it looks good and can give its antec counterparts a run for their money. i am using it for 8 months with a p4 3.0... no over heating issues...
915g not enough to comfortably play any new game.....even with a 3.0 ghz p4 and 1024mb ram....does anyone know a solution(plz dont tell me to add a graphics card...) |
#17 (permalink) | |
#18 (permalink) | |
cud u please post sum pics of it?the ones on kunhar site r not that detailed.
#19 (permalink) |
Guys when somebody asks about cabs. all everybody has to say is Antec....i am sick of this...amn i ain't gonna spend 9K for a Cab!!!
check out this link :http://www.kunhar.com/vipcabinets/gaming.html i personally bought the G300 Model and installed 5 Fans!!! all this in 4K. |
#20 (permalink) |
how much g300 costs without smps... i have a powersafe smps which i will be using..... and intel mobo require an i/o sheild... will it fit in the cabinet... i have a 865 gbf mobo......
#21 (permalink) |
VIP 1122 costs 1 k to max 1150 without psu
VIP G 100 costs 2.1k to 2.3 k without psu .. VIP G 200 costs 2.5 k without psu VIP G 300 costs 3 k without psu all are mumbai prices .. now u want transparent cabinet then go for G 100 its damn good .. I am using 1122 which is very good too ..just that G 100 is taller , and much broader than 1122 .. and if u want a very good quality cabinet without transparent side window then .. G 300 suits the bill .. |
#23 (permalink) |
thanks yogi7272... i would most probably go for g 100.....I know the quality is very good and the ventilation will be also good with no heating problems.... but can someone comment on its features like.......
1. how many hdd it can hold 2. How quiet does it perform
#26 (permalink) |
VIP 1122
DRIVE BAYS: 4+2 FRONT PANEL: 2 USB PORTS, HEADPHONE JACK MIC I PRICE...NOT INCLUSIVE OF SMPS.....1600 EXTRA FOR 400W VIP SMPS NO REAR EXAUST INCLUDED....USE A 120MM FAN.....80MM FANS SOUND LIKE JET ENGINES..... SORRY FOR THE DELAY...
#27 (permalink) | |
Hmmm...do i need one? |
#29 (permalink) | ||
#30 (permalink) | |||
To both of you.... Read THE DA VINCI CODE.... may be you could find a chisile or hammer used by DA VINCI himself......
| Bookmarks |
| Thread Tools | |
| Display Modes | |
