Old 08-01-2006, 06:22 PM   #1 (permalink)
Default suggest external hard disc upto 100GB
hi friens
plz suggest me a good external hard disc which is upto 100GB.
but it should be external!
n plz tell me can external hard discs can attach via USB 2.0??
plz reply me earlier........
.:;AddICtEd;:. is offline
Old 08-01-2006, 07:50 PM   #2 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
external and portable HD's are a real use full thing
seagate-100gb-st9100801u2-rk
5400rpm
it can be attached to the USB2 interface
vijay_7287 is offline
Old 08-01-2006, 08:46 PM   #3 (permalink)
jay4u's Avatar
i would say to go for what vijay_7287 said... its a really nice one... and SEAGATE rocks...
Else you can buy a laptop hard disc and then use a good hdd casing... like one from intex / frontec and ow... u save a lot of bucks also... howwzaat
Passwords are like underwear... Change them often...
jay4u is offline
Old 08-01-2006, 09:37 PM   #4 (permalink)
Yoy can also use your IDE harsdisks to connect to a ide to usb box.
IOmega exernal usb hdds are very good perpormers.And also not very heavy on your pocket.
Or buy the trancend casing to use small laptop hdds
through usb.
amitsaudy is offline
Old 09-01-2006, 12:07 AM   #5 (permalink)
jay4u's Avatar
yes amitsaudy... that's what i said..... used ur present hdd and buy a new casing and save the money.... and yes USB 2 gives a very good transfer rates...
jay4u is offline
Old 09-01-2006, 02:39 PM   #6 (permalink)
there r some pretty good usb cases from Pinnacle
ashnik is offline
Old 09-01-2006, 06:36 PM   #7 (permalink)
1st of all u should know that 3.5 inch HDD casings require external power supply.. even the original HDD's..
2.5 very expensive 100GB..
so u decide..
I\'M BACK
khandu is offline
Old 10-01-2006, 03:37 PM   #8 (permalink)
Default thanks all for the advice
hi friens
thanx 4 the advice in case of the external hdd.............
now i am thinking to have a external portable hdd by seagate
am i @ right direction
Old 10-01-2006, 04:41 PM   #9 (permalink)
Wandering in time...
Ankur Gupta's Avatar
i too want 2 want buy a good usb case.cud u plz suggest me some with their prices.
and as khandu said they require external power supply wat did he mean by even original hdds.and does the case's xternal supply connect directly to2 AC power supply or some other way.
thanx in advance
Ankur Gupta is offline
Old 10-01-2006, 11:06 PM   #10 (permalink)
I would suggest Maxtor External drives. They offer good performance. But they might be pricey if available here. Buying a 3.5" drive + casing is a good, cheap option but make sure you get good quality casing else you could ruin the HDD. And as has been mentioned already, 2.5" HDDs are expensive and slow as compared to 3.5" ones.
Nemesis is offline
Old 10-01-2006, 11:35 PM   #11 (permalink)
I am using a 2.5" 40GB hDD + Casing.. excellent.. costed less than 5G.. and usb powered
try www.lacie.com they are also cheap..
I\'M BACK
khandu is offline
Old 11-01-2006, 02:17 PM   #12 (permalink)
So if a buy a 40GB hdd and a USB case will it fit in my budget of 2.5k?
also wat are the rates for 2.5" and 3.5" 40GB HDDs?? and which company shud i opt for???
