Old 07-01-2006, 01:57 PM   #1 (permalink)
Default Comapring Products..
I have a DFI Lanparty UltraD mobo..
It has karajan audio ( using AC,97 codec ) .. If i but a Creative Live 24 bit card.. how much affect in sound it will be ??
is it worth it ??? or ne better sound card.. some dealer suggested some 7.1 card.. I am using Creative Inspire 5200 Speakers..
Also comparing Pinnacle 110i and Compro Gold Plus II .. whats better.. ?? cause Gold Plus II is not available in mumbai at moment
Budget for sound card ( if needed ) : Rs. 5000
for TV Tuner Card : Rs. 5000
waitin for suggestions..
I\'M BACK
khandu is offline
Old 07-01-2006, 04:00 PM   #2 (permalink)
any external soundcard will be great....even a creative live 24bit
Hmmm...do i need one?
sunmysore is offline
Old 07-01-2006, 10:41 PM   #3 (permalink)
The Hardware Labs
mohit's Avatar
here are some screenies from anandtech wich compare different onboard sound chips .. they have compared onboard creative sb live and karajan also. u can see the difference .. its not much and an onboard sb live will be performing equally as an external sb live 7.1 i guess.
and herez the link to the complete review,
http://www.anandtech.com/mb/showdoc.aspx?i=2465&p=27
mohit is offline
Old 08-01-2006, 12:08 PM   #4 (permalink)
phatratt's Avatar
hey dude I have Creative sound blaster live 24bit which supports upto 7.1 speakers and features like EAX.It costs around 2K bucks excluding taxes 8months back.It was a perfect upgrade for my onboard AC97 sound.there was quiet a lot of improvement on audio cd and gaming front.Sad part is am having a creative 2.1 sbs speakers which does'nt allows me to unleash its full potential.
there is one disadvantages.Sound get choppy,distorted while performing multiple tasks and listening to songs at the same time and the same happens
while playing games too(occasionally)
phatratt is offline
