Old 06-01-2006, 10:25 PM   #1 (permalink)
Default RAM problem
friends, i m facing a strange problem.
i hav 2 sd ram 133 mhz each.both of hynix.
the problem is that i cannot start my computer when both the RAMs are inserted in the slots together.the BLUE screen comes with some messages when my window xp starts loading.
i hav tried booting my system with 1 RAM at a time and it works just fine in both the slots.so the problem arises when both the RAMs are inserted together.
plz help me!!!!
i would like to tell u people that some time before i was facing this same problem .but in that case 1 RAM was faulty so i changed that RAM and brought the new one of same frequency i.e 133 mhz.but again i m facing the same problem dis time both the RAMs functioning properly.
->Whatever Happens, happen for A Reason!!!!!
My new blog-Aarambh
http://www.rakshitk.com
A Place to share thoughts with like minded people.
roxisayshi is offline
Old 06-01-2006, 11:20 PM   #2 (permalink)
jay4u's Avatar
if u r damm sure that both rams are fine.. amd i mean really fine.. then i think its the ram slot that is causing the problem......
since the comp runs fine with one ram... any one ram ... and if u have 3 or 4 slots ... try using different combination of slots.....
Passwords are like underwear... Change them often...
jay4u is offline
Old 06-01-2006, 11:20 PM   #3 (permalink)
jay4u's Avatar
jay4u is offline
Old 07-01-2006, 10:24 AM   #4 (permalink)
hi jay4u
i hav only two RAm slots on my mobo and i hav tried both of them .they are working fine with both the RAMs.
My new blog-Aarambh
Old 07-01-2006, 10:42 AM   #5 (permalink)
dIgItaL_BrAt's Avatar
Both the RAM chips are incompatible with each other,buy a chip which is the same as one of the chips u already have (same manufacturer).
dIgItaL_BrAt is offline
Old 07-01-2006, 10:52 AM   #6 (permalink)
hi digital_brat
i hav both the RAMs of hynix and i hav been using it for 1 year.
My new blog-Aarambh
Old 07-01-2006, 03:49 PM   #7 (permalink)
Try cleaning the RAM slots....& then try using them with the existing stix which u have...Also try using 2 altogether different RAM stix & check whether they work in tandem....
HK
h_kunte is offline
Old 08-01-2006, 12:05 PM   #8 (permalink)
::cyborg::'s Avatar
incomatibility issue sir
::cyborg:: is offline
Old 08-01-2006, 12:23 PM   #9 (permalink)
phatratt's Avatar
u r facing incompatiblity problems,try installing a 100mhz stick and check if the problem occurs.If the RAM is completely doomed u pc will refuse to boot and starts crying with a looong beep.
phatratt is offline
Old 08-01-2006, 10:20 PM   #10 (permalink)
thax for the support.
but is this possible thar two RAMs of same frequency and of same manufacturer hav incompatibility problem?
may be my mobo has some fault..........
My new blog-Aarambh
Old 09-01-2006, 11:53 AM   #11 (permalink)
phatratt's Avatar
nope not a problem at all if u have 2 RAM sticks with same frequency and same manufacturers,infact I have 2 RAM sticks of 128MB each with one being HYNIX and the other Kingston,I don't find any problem with same or different manufacturers,its the frequenct that matters.Check u'r mobo manual if it supports 133mhz if it does then u'r mobo could be at fault.
Also there are several mobo which comes with 4 slots(A,B,C,D)try installing on alternate slots like A&C or B&D not A&B or C&D it can be easily identified by colour coding.This means they support double bandwidth mode or something like that(correct me if I am wrong)
phatratt is offline
Old 09-01-2006, 03:44 PM   #12 (permalink)
hi phatratt
i am using these 133mhz RAM chips for the past 1 year.so my mobo does support the RAMs of this frequency.
so now i m sure that problem is with my mobo.
My new blog-Aarambh
