Old 06-01-2006, 02:42 PM   #1 (permalink)
abhishek_sharma's Avatar
Default problem with lgcdrw
These days my lg cd-writer cannot detect any cds ...even when there is a cd/or no cd in the drive windows xp just opens the drive folder and shows nothing [in natural conditions it should have shown no-disk error when no cd and the files in the cd..when a valid cd was present]
also sometimes the cd writer cannot get detected at all.. which i think is due to the loose power connection to the drive which is a bit loose.
how to get rid of the above problems..plz help.
does it mean that my cdwriter is on its death-bed
abhishek_sharma is offline
Old 06-01-2006, 02:58 PM   #2 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Check ur power cable also if that doesnt help, try changing the IDE cable.
Now for ur problem tat the Drive is not Detecting any Cds, it might be due to accumulation of dust on the Lens,get a Philips CD Lens Cleaner (approx. Rs.120/-) and try it out.
How Old is ur Drive brother ?? If under warranty then giv it to the service center (after all the above troubleshooting has failed).
Cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 06-01-2006, 09:29 PM   #3 (permalink)
phatratt's Avatar
1)change data cable and try on a alternate power cable
2.)also check that all th pins(power and data) on back of the writer are intact.
3)if u'r writer is old,then it has enter its saturation period,get a new one
phatratt is offline
Old 07-01-2006, 07:37 AM   #4 (permalink)
this will help u .
nice tips phatratt
hermit is offline
Old 08-01-2006, 10:04 AM   #5 (permalink)
ymhatre's Avatar
Default Re: problem with lgcdrw
Same problem did happen with my samsung Cd rom
It used to open cd tray ,worked fine, even is bios it was detected but in windows it was not reading.
Then i at my own risk OPENED CD ROM (literaly) then just cleaned it, it was having lot dust inside.
Then it started working ie started reading cds
before trying this stuff plz try using lens cleanner
DusT = ME
Rate me if was clear to you
ymhatre is offline
