Old 05-01-2006, 02:00 AM   #1 (permalink)
Default Hard Disk problem
For the past one day my Hard disk has been making a strang noice ie. of BUZZZZiiing
it is not that loud so as to be heard in the day but it is definitely not usual to my system.
i mean my hard disk never made such a noice.
Its a Samsung 40 GB Hard Disk.....
Will this cause any damage in future and is there a curative measure.
Plz help.
nitinjavakid is offline
Old 05-01-2006, 09:01 AM   #2 (permalink)
shariq_pj's Avatar
Hmmmm... Ur had disk is about take a nose dive...
Try running some diagnostics and check...
Ther's every chance of ur harddisk gettin crashed after a few days...
Sh@riq
<size=24>P R ! V ! L E G E</size>
shariq_pj is offline
Old 05-01-2006, 09:39 PM   #3 (permalink)
ymhatre's Avatar
Nitin u try running some diagonis like scandisk in thorough mode or deframgentation from norton utilities etc
and yes monitor ur hdd using utility frm is thread
http://www.snapfiles.com/get/hddhealth.html
or
http://www.panterasoft.com/
HOPE it wont get crashed as said by shariq_pj
Dont take chances better back up ur important data in CDs
Eventhough i feel tht ur HDD is fine only a minute noise is still OK and ur HDD will last for abt minimum for 3 year.
Yes do take care tht u dont Fully format ur HDD
coz i had heard tht quick format dont coz ware & tear of HDD but full format does sometimes
also u can check the following thread for HDD formatting issue
http://www.frihost.com/forums/vt-20333.html
ymhatre is offline
Old 06-01-2006, 03:05 PM   #4 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Its not Probably But Definately on its way for a death and Rest In Peace situation coz the same thing happened with my 40 GB PATA Samsung HDD and now i hv purchased a new Seagate 160 GB SATA HDD for Rs.4500/-
Please backup ur Data and Do not spend time in thinking as to wat shud be done to correct ur HDD problem coz the next time u start ur PC, it might not even boot. Im not scaring u brother but jus a alearting signal.
For a curative measure,u can giv it to the Service Center for repair (but that will not help u much) as after 1 year u will face the same problems again.Try it and giv ur best shot. Best of Luck.
NB: As of now my old Samsung 40 GB PATA HDD is used as a Paper weight......
Cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 06-01-2006, 09:13 PM   #5 (permalink)
phatratt's Avatar
samsung harddisks are quiet famous for that,one of my friends had similar problems,he just dumped it and got a new HDD(segate 80GB) 8)
phatratt is offline
