Old 04-01-2006, 08:50 PM   #1 (permalink)
Default DVD and Cd Drive problem!!!!!!!
This problem is eating my head.
My computer cannot recognize neither my samsung dvd drive or liteon cd drive. This problem occured a week earliar too, at that time i formatted the computer but now i don't want to delete all the files. What is happening.
There r no drivers for the drives. PLEASE HELP!!!!!!!!!
pranavrahul is offline
Old 04-01-2006, 09:52 PM   #2 (permalink)
posting the config, more details like OS might help us to solve ur prob
Shwetanshu Srivastava
shwetanshu is offline
Old 04-01-2006, 10:19 PM   #3 (permalink)
Default WIN XP
I have Windows xp professional service pack 2.
Old 05-01-2006, 07:54 AM   #4 (permalink)
check ide cable .
hermit is offline
Old 05-01-2006, 10:02 PM   #5 (permalink)
Default IDE cable
I have checked ide cable too, but it didn't work. I checked the power supply too, but its not power supply!
Old 05-01-2006, 11:40 PM   #6 (permalink)
blackleopard92's Avatar
try putting samsung drive and liteon on seperate cables.
And vow never to buy Samsung again.
Sansung is an alias of problems.
blackleopard92 is offline
Old 06-01-2006, 02:37 PM   #7 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
First of all just connect any one of ur drives (either Samsung or Liteon) and start ur PC and let it detect it in BIOS and also in My Computer. Now shut down and connect the other drive.
Be sure to check the Jumper setting please...
And see in BIOS if this is also detected.
IF not...then possibilities:
Remove the CMOS battery and insert it after gap of 5-minutes.
IDE Cable gone corrupt.Buy a new cable.
Check Jumper setting.It may be wrongly adjusted.
At the last resort...
IDE slot gone corrupt.Give it to the Company service center.
Totally agree with u brother.. !! I myself hv a CD ROM and a CD Writer from Samsung and jus waiting till it reaches its Death.Till then im forced to use this.
Cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 06-01-2006, 09:56 PM   #8 (permalink)
phatratt's Avatar
u'r IDE controller could be doomed.Try thses steps.
1)connect both optical drives on the primary IDE slot and ur HDD to secondnary IDE slot and switch on the pc.If both optical drives get detected and HDD fails to do so then the secondnary IDE is at fault.
2)Which motherboard r u using???try updating the BIOS
3)Have u disabled the the secondnary IDE at the BIOS???
4)SInce its a Samsung drive,famous for failures so just disconnect it and use the lite on drive and also vice-versa.the latter could be the culprit.
phatratt is offline
