Old 24-12-2005, 01:29 PM   #1 (permalink)
slugger's Avatar
Default CD-ROM Drive tray Not opening
I got a Creative 26X CD-ROM drive. Since the past couple of days, the tray of the drive refuses to open up. I tried conneting it to a different IDE channel, changed the power cable, disconnected it then again reconnected it, but to no avail.
Can anybody please tell me what to do to solve this problem. I wish to streach the life of this Drive by just 6 more months max.
slugger is offline
Old 24-12-2005, 01:45 PM   #2 (permalink)
MVP in VC++
Creative 26X CD-ROM drive Oops i don't know how old it is...
i think it has become dead.....Hey try to plan for new optical drive
cvvikram is offline
Old 24-12-2005, 02:17 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
If theres some CD trapped in it then see the drive front bezel.. u will see a tiny hole if seen carefully.. put in a long stick/needle that can pass in and press into it. the tray will pop out and u can remove the CD..
also check if there is something blocking it...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 26-12-2005, 05:26 PM   #4 (permalink)
mithun_mrg's Avatar
Default Re: CD-ROM Drive tray Not opening
take a office clip pin insert in the small hole in front panel of ur cd rom until the drive ejects then power up ur pc
mithun_mrg is online now
Old 26-12-2005, 10:41 PM   #5 (permalink)
Wire muncher!
infra_red_dude's Avatar
it seems either the motor or the belt is causing the problem. try to remove the tray as suggested above. while removing the tray observe if the belt (or the gear system, wotever the case maybe) is intact. if it is, then most probably the motor has gone kaput.
infra_red_dude is offline
Old 29-12-2005, 09:13 AM   #6 (permalink)
slugger's Avatar
thanx a ton 4 reminding me of the feature which i had all but forgotten. hopefully i can streach its life 4 6 more months
thanx again
slugger is offline
