Old 18-12-2005, 12:07 PM   #1 (permalink)
Default Gaming With LCD Monitor
Hi Gammer,
I want to buy GAming PC with LCD monitor. Can you please share your experience regarding gaming with LCD monitor.
sukanta is offline
Old 18-12-2005, 12:19 PM   #2 (permalink)
d
Gaming with an LCD monitor eh? the monitor as such will look good...but u'll hv to splurge on the monitor itself.....as for decent and ghost-less gaming u will hv to get an LCD monitor that has the least response time like wht's advertised as the fastest LCD from viewsonic....takes 3 ms....the model no. is VX724 for 17" and VX924 for 19" monitor....n work upwards according to ur budget....i'd recommend an LCD with a time of atleast 8 ms....anything more than that will produce ghosting
The torquemaster rules.
d is offline
Old 18-12-2005, 01:40 PM   #3 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
it totally depends onwat type of a gamer u r
if r a real gaminfreak then the LCD is not ur cup of tea
but if wanna go for the look of it
then a 17 inch lcd with an 8ms response time or less
it wont be a real compromise as such if u r not hardcore gamerwho can realize the difference
vijay_7287 is offline
