umm...restarted suddenly, as in just like that? no other symptoms? cld we hv some more symptoms plzz? like is this happening only after u changed the SMPS?
reminds me of a friend whose computer wld restart everytime he flushed the toilet....turns out when he flushes the toilet, a pump wld start, causing a dip in the power supply n restarting the comp
Hi friend
is there any particular duration when the problem occurs...i mean does it happen when you are playing games....if thats the case then this could be due to heating problem of your mobo...in such a case you might consider adding an additional fan..or going for a bigger CPU case..
yea check ur ram by using memtest86 i think its surely the ram i jus had de same problem around a week back i had 2 rams of 256mb ddr n de comp wud alwayz restart i took out one n everythin seems to be in place..
