Old 08-12-2005, 05:29 PM   #1 (permalink)
Default Core clock speed..?
I have a problem which i am not sure about.
I bought an ASUS 6600 GT with AMD 3000+ and ASUS A8NE Along with 1 GB RAM. i got a score of 2780 in 3D MARK 05.
it was ok for me but then i noticed that it said that memory clock of the card was 1012 Mhz while VGA core clock was 301 Mhz.
Is not the core clock of 6600Gt 500 Mhz.
samanvya_ad is offline
Old 08-12-2005, 05:59 PM   #2 (permalink)
Manchester United
abhijit_reddevil's Avatar
Ok, let's see, try the results from Rivatuner, it should give correct results. You can download that from www.guru3d.com.
abhijit_reddevil is offline
Old 08-12-2005, 07:16 PM   #3 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
please check this thread to find ur answers !!!
http://www.thinkdigit.com/forum/viewtopic.php?t=13761
vijay_7287 is offline
Old 08-12-2005, 08:59 PM   #4 (permalink)
Location: formerly black mesa resarch center,now city 17,india
have u tried updating ur drivers may be that can solve it.also is the 3d mark scoremin. or max?
I\'ll give u my rigs config once u give me the rig!
asdf1223 is offline
Old 10-12-2005, 10:50 AM   #5 (permalink)
Its strange its always giving different things.......... Just now i saw 9.7 Mhz.
So now i am convinced its prob with 3D mark 05 n not the card as one of the provided asus utility shows 500 Mhz.
i got a score of 3590 this time continously for two trials.....
Old 10-12-2005, 04:50 PM   #6 (permalink)
i guess a 3-4k score is pretty normal for a 6600gt.so i guess ur problem is solved.
asdf1223 is offline
