30-11-2005, 05:07 PM
No sound from right speaker
Guys...
It's urgent guys...
I'm not able to hear any sound in my PC's right speaker...
I checked all the volume properties and the audio settings in the control panel... But no go...
Help me out guys...
Sh@riq
<size=24>P R ! V ! L E G E</size>
30-11-2005, 05:11 PM
Microsoft MVP
Once when I brought new Creative speakers, same problem happened to me also.
The solution was, I had to purchase a Sound card, then the sound started coming from both speakers
30-11-2005, 05:17 PM
I hav this ALtec Lansing speakers...
They were workin pretty fine for the past few months...
I'm noticin this jus today...
Sh@riq
30-11-2005, 05:50 PM
Dude check if the speakers are working. Plug it in to a walkman or something and check. Maybe the cable has got broken or got pulled out.
30-11-2005, 07:05 PM
Do as LordDJ said........
Still problem...?
Take it to the nearest audio repair guy, might be a prob with the power transistors inside the unit....
I had the same problem, so replaced the transistors @ 100 bucks.....
30-11-2005, 07:38 PM
Also, if possible, try switching the left and right channels by interchanging the connection wires. If that still gives you a problem, then it has to be an issue with your computer. But if the right speaker still gives no sound (after being switched to left), then it's a problem with that speaker.
30-11-2005, 07:44 PM
I checked with all the cord connection... everythin is proper... and the speakers work with the walkman very well...
I tried uninstallin and reinstallin the audio driver... No go...
I ave an ASUS P5gv-tmx board...
Sh@riq
30-11-2005, 07:52 PM
Commander in Chief
check if any dust/obstruction is on the pin of the speakers or in the jack and try adjusting the connection.
My headphones sometimes play only one side but when i rotate and adjust the pin in the socket it workx fine...
Harsh J
www.harshj.com
30-11-2005, 08:52 PM
Wire muncher!
i think the problem is connected wid the soundcard coz the speakers play fine with the walkman. check the connector on the soundcard.
attach a different set of speakers/headphones to the soundcard and check. since you've reinstalled the driver you've eliminated any software issues.
ps: haf u been playin around wid the soundcard? one of my friends blew up the right channel of the soundcard while messing wid it!
01-12-2005, 01:14 PM
It's integrated audio...
I did'nt mess around with the audio part of my motherboard... The speakers were jus workin fine and I don't know when all this happened since I started noticin it yesterday...
I jus play NFS and Doom3 on my comp... Well that's what I had been doin...
I checked the same with a set of headphones... Same thing's happenin...
My Tower has a phones jack in the front panel... I tried connectin the speakers to that port too... Still the same problem...
This problem seems very peculiar to me...
Sh@riq
01-12-2005, 05:27 PM
Wire muncher!
then ur soundcard's the culprit! if you hafnt messed up wid ur system then it's probably a problem wid the connector!
01-12-2005, 05:40 PM
Macboy
soundcard...
I'm like a bird... :)
03-12-2005, 05:47 PM
Will I have to replace the mobo...?
Sh@riq
03-12-2005, 06:16 PM
Commander in Chief
get a PCI soundcard instead of changing ur Mobo
Harsh J
www.harshj.com
04-12-2005, 07:22 PM
need to change your speakers !!
Smile a lot
it costs nothing
04-12-2005, 10:35 PM
Speakers work fine with the walkman and any other input...
Sh@riq
04-12-2005, 10:36 PM
get a new soundcard.
06-12-2005, 10:19 AM
Thankfully the system is in warranty period... So i think i'll replace the mobo....
Sh@riq
07-12-2005, 04:41 PM
#19 (permalink)
Sh@riq
07-12-2005, 08:25 PM
#20 (permalink)
congrats
