Even same thing happened with me. I think Windows XP just puts the icon there for no aparent reason, since when I installed XP on my system the Floppy was disable from the BIOS and even then , It showed the Floppy drive icon in My Computer folder.
This could be a bug in the OS itself.
Solution:
I used TweakUI to hide it. So, you can also try doing the same. good luck.
i think disbaling or setting the option as not installed in the BIOS will solve the problem so try it out and let me know, i tried it on my PC and it worked
fighting for peace is like ****ing for virginity
it is not working on my pc... the fdd drive still shows in MY COMPUTER... and yes TweakUI can hide it but i am interested in knowing why Xp does it this was.... Does it believe that every computer has a floppy drive.....
Passwords are like underwear... Change them often...
