Old 29-11-2005, 03:32 PM   #1 (permalink)
Location: a small room in a big house in a small street in a big city
Default sharing an USB device
Is there anyway to share a USB device between two or more computers over a LAN.
The USB device is not recognised as a separate drive by XP and so it doesn't show anywhere in the Explorer window.
Can you help?
netarget is offline
Old 29-11-2005, 03:37 PM   #2 (permalink)
What exactly is the USB Device u have, as if its not showing in the explorer, how r u using it or..... its a camera or something which u use with some splecialized software ?
mangemayur is offline
Old 29-11-2005, 06:06 PM   #3 (permalink)
Yep. Its a special device.. more like a Key to use with a particular software.
Hooray for games. (unfortunately i cant play any of \'em)
netarget is offline
Old 30-11-2005, 05:56 PM   #4 (permalink)
Dude they usually don't make security dongles that easy to crack!!
LordDJ is offline
Old 30-11-2005, 07:07 PM   #5 (permalink)
ramprasad's Avatar
No way..... if its a dongle....
ramprasad is online now
Old 30-11-2005, 07:09 PM   #6 (permalink)
NOP Sir, u cant do that, only the storage devices can be shared
