| Forum |
#1 (permalink) |
my problem is when i connect both pata and sata together, i cannot install any os xp,linux etc.., the mboard gives that beep beep beep .. sound when i disconnect pata 80gb hdd then installation is smooth, after installing if i connect that 80gb hdd, no problem arises, what should i do plz help bye gowthaman |
#2 (permalink) |
SNIST Screamer !!
well might be a prob in the config of the bios
just check whether both the disks are configured as master if so try try configuring the pata as slave if succede post back !!!!
http://snistscreamers.blogspot.com/ http://insidevoidmain.blogspot.com/ SNIST-Blog: the Voice of SNIST... http://www.snistblog.com/ |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
