Old 27-11-2005, 06:59 PM   #1 (permalink)
Default SATA to PATA
Got a 80GB SATA HDD.Want to use it in a 815 motherboard as PATA.Is it possible?If yes whats the procedure?
ra_sriniketan is offline
Old 27-11-2005, 07:03 PM   #2 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
even i need tht piece of info
anyone please answer !!!!
vijay_7287 is offline
Old 27-11-2005, 07:49 PM   #3 (permalink)
A SATA HDD has no connection for a PATA cable as simple as that,so you cant do anything
rachitar is offline
Old 27-11-2005, 08:00 PM   #4 (permalink)
Isn't there a parallel port in SATA HDD?
Old 27-11-2005, 10:41 PM   #5 (permalink)
The Hardware Labs
mohit's Avatar
no
mohit is offline
Old 27-11-2005, 10:43 PM   #6 (permalink)
then i don think its possible
hummer is offline
