Old 27-11-2005, 06:37 PM   #1 (permalink)
Default Deleted partitions in a 80GB hard disk
Hi,
I have a 80 GB hard disk, FAT32 partitions which was running fine till recently. But one fine day it showed boot error. When i booted from a floppy the partitions did not show, I suppose the partitions have been deleted somehow.
But what i need now is can someone help me in recovering the partitions and the huge data that I had stored in my Hard disk. Would Norton Disk Doctor help if I run it from a separate Hard Disk? Any other more efficient software that would be more helpful, please suggest.
Regards
steelcold is offline
Old 27-11-2005, 07:01 PM   #2 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
i think ur case needs more finner details
the path u are thinkin of is the right one
try reachin it with another harddisk
but if it fails then i guess the file system is gone
norton disk doctor only helps in recovering bad sectors , not unreachable sectors , so reach it first and repair it next !!!!
vijay_7287 is offline
