Old 27-11-2005, 12:58 AM   #1 (permalink)
Default ps2 connectivity blues
[color=brown]my ps2 conectivity on mobo nt wrkng when i plug my kbrd it`s light blinks it does not wrk same is fr mse hlp me wht 2 do i tried ps2 2 usb flop wht 2 do sos!................
brat_p2p is offline
Old 27-11-2005, 07:15 PM   #2 (permalink)
the connector might be broken...if ur keyboard mouse work using a ps2 to usb converter, then get the connectors on the mobo checked...
Nitin Garg...
madman123 is offline
Old 01-12-2005, 09:56 PM   #3 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
go to run type dxdiag
and check the deviced tab where ps/2 devices are shown
if it shows a prob then might be software bug
if it doesn't then get the mobo checked
vijay_7287 is offline
