Old 26-11-2005, 08:29 PM   #1 (permalink)
Default Difference between SATA & PATA Disks
Friends,
Can anyone please explain me the differences between a SATA Hdd & a PATA? Is the difference only in the connecting cable & cable slot?
Please throw light on all possible differences.
Also, why is the price difference between the two types so large?
Thanx.
h_kunte is offline
Old 26-11-2005, 08:43 PM   #2 (permalink)
hmm...no offence, but that is asking what the difference between a bicycle and a car is...SATA(serial ata) is much faster the (parallen ata) which uses a much older technology...sata us basically the norm right now...and the thing to watch out for is SATA2
Nitin Garg...
madman123 is offline
Old 26-11-2005, 08:54 PM   #3 (permalink)
rachitboom2's Avatar
As we all know that SATA is dam faster than PATA so no need to mention all that again but if you have a dam stylish cabinate with all the cooling stuff and transparent cabinate then its pretty good as its cabels are far thin than IDE cabels !!!
Hence better looks and proper air circulation !!!
Laptop: HP DV6 - 6017TX: Intel Core i7 + 4GB DDR3 + ATI HD6770
Cell Phone: NEW Samsung Galaxy S2 i9100 16GB
Console: Xbox 360 Arcade 250GB
Gamertag: Rachitmayhem
mahule_rachit@yahoo.com
rachitboom2 is offline
Old 26-11-2005, 08:59 PM   #4 (permalink)
SATA and (P)ATA have different cables and chipsets
SATA is not supported on some linux flavours and versions and you will have to download the source code and compile it accordingly
rachitar is offline
Old 26-11-2005, 09:10 PM   #5 (permalink)
That is old news nowa days almost every distro. of linux supports SATA !!!
Old 26-11-2005, 11:47 PM   #6 (permalink)
http://linuxmafia.com/faq/Hardware/sata.html
I didnt say Linux will not install,it will give you problems, like FC 4 has been giving me
To get rid of the problem,you need to download the kernel sourcecode and compile it on your comp
rachitar is offline
Old 27-11-2005, 12:58 AM   #7 (permalink)
PATA used to transfer data using parallel interface thats why it had so many pins which resulted in the increased width of the connector (IDE). Sata does it using serial one. SATA is much much faster n there is no difference in the costs of the both varieties.
I have successfully installed FC4 on my Seagate SATA.
Monster_AMD is offline
Old 27-11-2005, 03:41 PM   #8 (permalink)
Yaa thats what I said that it will install on linux !!!
Oh and SATA costs a bit higher that PATA dude !!!
Old 27-11-2005, 07:24 PM   #9 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
the one number tht goes against sata is
its got only one connector per port
but the ide thing has two
still SATA rules !!!!
vijay_7287 is offline
Old 28-11-2005, 01:56 PM   #10 (permalink)
That dosent makes any diff. as we have to connect other optical drives too on IDE, so its all together the same only !!!
Old 28-11-2005, 03:24 PM   #11 (permalink)
The Hardware Labs
mohit's Avatar
Please search the forum before posting your queries, this topic has been discussed many times before.
see HERE and HERE
mohit is offline
Old 28-11-2005, 10:30 PM   #12 (permalink)
see HERE and HERE
But that dosent makes any diff. as again in a few days someone else will again start a thread of such sort !!!
Old 29-11-2005, 07:36 AM   #13 (permalink)
No point in locking the thread now that so many people have replied to the original post.
@h_kunte: Please make use of the Search function before starting new threads.
Nemesis is offline
Old 29-11-2005, 01:36 PM   #14 (permalink)
is it mentioned in the rulz that you have to first search and then start a new topic, if not then pls. add it in it !!!
Old 29-11-2005, 04:13 PM   #15 (permalink)
The Hardware Labs
mohit's Avatar
@rachit
instead of talking nonsense and giving crapy suggestions why dont u help in keeping the forum clean and uncluttered ? there is no need for a rule on searching before posting , its just common sense and also a good habit inorder to avoid the same n same n same posts again n again.
mohit is offline
