| Forum |
#1 (permalink) |
One Beep : Quote: DRAM refresh failure This may be due to - Bad memory chips - A bad DMA Chip - Bad memory addressing chips on the motherboard Two Beeps : Quote: Parity error or Parity Circuit failure Your memory may not be seated properly on the mother board. Unplug and plug it properly Three Beeps : Quote:Bad memory or bad mother board Four beeps : Quote:Timer failure in the RAM. Five Beeps : Quote:CPU chip may be dead Six Beeps : Quote:Keyboard controller may have failed Seven beeps : Quote:CPU is dead. Retry the connections and test. Replace the whole motherboard. Eight Beeps : Quote:Video card is missing or Bad. Nine Beeps : Quoteamaged ROM BIOS. BIOS chip has to be replaced if it persists. Ten Beeps : Quote:CMOS shutdown. Replace CMOS memory and associated chips. Eleven Beeps : Quote: Cache memory test has failed. To enable cache memory try CTRL+ALT+SHIFT++. One long Beep and Three short Beeps: Quote:Memory failure One long Beep and Eight short Beeps : Quote:Video card failure. Try to install video card in another slot. No Beeps : Quote:Check Power supply Check mother board connections Remove all cards except video card and check for system power up Insert all cards one at a time and check their operation. If system hangs on the installation of a particular card, then it is the cause for the problem and replace it with another of that type and check |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
