| Forum |
#1 (permalink) |
Wandering in time...
#2 (permalink) |
The Hardware Labs
Intel Pentium D 2.8 Ghz costs only 12,500/- bucks and AMD 4200-X2 is for around 26,500/- ..the most important criteria is your budget buddy. AMD is the way to go if you want perfomance and Intel if just need your pc to be dual core. The prices will surely fall but nobody can predict exactly when. Dual core is still just gaining ground as there aren't many apps that benefit from it. I dont think prices will really shatter until the release of Windows Vista / dual core usable games /software etc all of which will surely be multithreaded and allow you to use your dual core processor to its full potential. Only then will people see some real perfomance gain. this is just my prediction.
#4 (permalink) | |
May be in the future there may be some such games but that will take a long time !!! Still if you are a gamer you can definately go for it !!!
Laptop: HP DV6 - 6017TX: Intel Core i7 + 4GB DDR3 + ATI HD6770 Cell Phone: NEW Samsung Galaxy S2 i9100 16GB Console: Xbox 360 Arcade 250GB Gamertag: Rachitmayhem mahule_rachit@yahoo.com |
#5 (permalink) |
I actually want 2 assemble a machine tht is future proof.applications and games utilizing dual core processing power will come out some time or other.as i plan not 2 upgrade for atleasr 3-4 yrs i thought i might go for a dual core rig.also the price mentioned above for the intel processor is for pentium D 820 or 830?also which motherboard wud u suggest for the intel rig?also how much ram should i opt for and how much will it cost?i have a budget of 30K.
Integrate Yourself With The Latest Happenings..... www.ankur-gupta.com/blog |
#7 (permalink) |
The Hardware Labs
30k for a dual core machine ??? dats too less dude. is 30k only the budget for the procc and mobo n ram ??
see, intel pentium d 820 - 12.5k Intel/Asus 945/955 board - around 8-10k ddr2 667 mhz 512mb - around 3-4 k (not sure) or else amd, amd 3800 x2 - around 20k (not sure) asus a8n-e - around 5200/- 512*2 DDR 400 - around 5,500/- |
#8 (permalink) |
if i do go for a single core machine will i get i gud rig(only cpu) for 30K?if yes pls suggest both intel and amd options with prices.
#11 (permalink) | |
#12 (permalink) |
The Hardware Labs
2-3 years is what is called future proof dude.. even if it lasts 2 years it is to be called future proof. technology is changing at such a fast rate that its hard to find stuff that will be future proof for even a year now.
#13 (permalink) |
exactly i agree with mohit.new proc and mobo is being launched every month or 2 so nothing can b future proof.at MAX it can b for for a year or 2.
@mohit i dont think 925 chipset support dual core proc |
#15 (permalink) |
although amd dual core performs better .. its costly right now .. better go with intel as costs are not that high ... also opt for Asus P5N32-SLI Deluxe-
best motherboard for intel processors right now .. |
#17 (permalink) |
For dual core, parallel threads are going on ...
http://www.thinkdigit.com/forum/viewtopic.php?t=32989 |
#18 (permalink) | |
#20 (permalink) |
Or falcon too hummer !!!
#21 (permalink) |
So u people donot recommend me to go for dual core! and of course i am buying the AMD monster for 26,500!! i thought dual core didnot have heating issues therefore it was introduced?
#24 (permalink) |
lord wha r u doin? there is an edit button on top of ur post .use it!!!
ya the bottom line is as gx mentioned go fr AMD 3500+ and overclock. 2 yrs down u can buy that dual core. that way u save some money and the system ll still b a monster. i don suggest intel coz i m amd fan. |
#25 (permalink) |
alright then its final i am goin wid amd athlon64 3500+ Venice with Asus A8N-E motherboard, & 1 GB kingston RAM.thanx a lot for guidin me!!!!!!
#26 (permalink) |
And you can buy some other gaget from the money you save from this config !!!
#27 (permalink) | |
Learner
Aother note... Intel dual cores might seem to be cheap but a poor performers... so there's not point getting them right now... and the cores communicate via external fsb... so even calling them "dual cores" is not right...
http://kniwor.wordpress.com/ |
#28 (permalink) |
k i admit that in a senario like u hv mentioned, eg. burnin a cd while playin a game or may b something thing else, there ll b diffrence. that ways there ll dif in bench marks 2. but the thing is i don thing u can play 2 really processor intensive app at 1 time. certainly u cant play doom3 n quake 4 at the same time. or run a game and a video editin app at the same time. so practically dual cores ll hv distinct edge in multithreaded app only.
wha say? |
#29 (permalink) |
Posts: n/a
well, windows itself is an OS, but to run windows XP U don't need the full 2 GHz of A cpu like athlon64 3200+
the thing is the usage of windows eats a lot less CPU resources, so even if u r using a single core CPU, which for general desktop usage, & gaming is what i prefer over the premium of Dual core when it comes to Workstation tasks, go for Dual core, that what i still say, for everything else, there is single core, buy dual core only after 2 years |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
