Old 24-11-2005, 03:10 PM   #1 (permalink)
Default A sub-30k Laptop ...?
After months of waiting and speculation, the sub Rs 10,000 desktop PC is finally here! HCL Infosystems, Sahara, and Xenitis now offer desktops that cost almost as much as camera cell phones. Never mind if they run Open Source Software, or if some use Chinese components. You can actually get work done on these machines using freeware that's easily available. And since certain laptops are available for around Rs 30,000, I presume the next target forthe industry is the sub-30K laptop. But is that
possible or just a dream?
If you're a newshound like me, you probably saw the report on the $100 (Rs 4,400) laptop being developed at Media Labs (Massachusetts Institute ofTechnology). This one's positioned at kids in developing countries. Media Labs co-founder, Nicholas Negroponte set up a nonÂ* profit group named One Laptop per Child (OLPC) to make this possible. The initiative was first 'announced by Negroponte at the World Economic Forum at Davos, Switzerland in January 2005. ilfyou want to learn more about this ambitious
project, point your browser to http://laptop. Ilmedia.mit.edu/
According to the web site, the proposed laptop will be Linux-based and have a color screen. While it won't be able to store a lot of data in secondary memory, these laptops will be WiFi and cell phoneÂ*enabled, and will have many USB ports -important for exchanging data and homework assignments.
Another highlight is the innovative backup power system-a wind-up crank style mechanism to supply the juice when you need it most. The laptop will be powered by a 500 MHz processor and will have 1GB of main memory.
A laptop can be a great learning tool and ,Negroponte sees this as an educational project not a laptop project. But if the $100 laptop does
emerge from Media Labs, and enters Indian '.ilspace, it will shake up the market. Laptop manufacturers will then create a new range of competing low priced models.
Now let's apply rationale and see if this will really happen.
Kalpak Bhatt, Product Manager at Gigabyte technology (India) does not believe that a b.30K laptop is possible - not anytime soon.
anyway because unlike desktops, there is no standardization in laptop architecture, and designs vary among manufacturers. So it's not possible to further reduce prices.
Bhatt explains, if there were industry-standard motherboard designs for notebooks (like those from Intel and AMD), and if all manufacturers used these standard designs, then prices could drop with volumes. But if you studied the internal design of two laptops from two manufacturers, you'd see quite a few differences. Though laptops have the usual components-power supply, hard disk, RAM, CPU, bus, chipsets - the manner in which these are interconnected differ greatly.
The miniaturization of components and tight integration also have a bearing on the overall price, because everyone has a different way of doing this. A laptop (especially the ultra-thin models) has very limited internal space. Its chassis has to be cleverly designed to accommodate all the standard components within a frame of standard dimensions. New features are incorporated into laptops every year, yet they are getting slimmer. So manufacturers devise their own designs to pack in more within the same frame. The technology used in laptop screens is also expensive. The TFT (thin film transistor) screen accounts for more than half of the total system cost. Yes, the cost of manufacturing TFT screens has declined in recent months, but not significantly. So if inventories are low it will raise the cost of TFT screens. To significantly reduce laptop prices, manufacturers need to create cheaper TFT screens or consider new display technology.
Cooling systems, power supplies, and battery technology also add to the cost. Manufacturers strive to make laptops that run longer on a single charge. With better battery technology (such as methanol fuel cells) this target will eventually be accomplished.
But laptops that run for longer durations also tend to heat up. So researchers are also working on efficient cooling systems, and figuring out ways to pack these into the slim laptop chassis. Laptop technology continues to evolve, and we know that new tech nology is a Iways expensive. So the sub-30K laptop is still a long way off, unless you settle for Negroponte's laptop. .
Computer.
Whats that.
Is it some kind of frog.. turr turr turrr...
con_tester is offline
Old 24-11-2005, 03:29 PM   #2 (permalink)
Uhu, Not Gonna Happen!
gagan007's Avatar
No comments.........
gagan007 is offline
Old 24-11-2005, 10:10 PM   #3 (permalink)
Huge Article.
I agree with you.
Sub 30 laptop is not possible this early
Renuka_Verma is offline
Old 24-11-2005, 10:21 PM   #4 (permalink)
The Hardware Labs
mohit's Avatar
man you have copied the entire article from this months chip ..why dint u post the source dude ? reporting to the mods as this is posted without a source. the source is page no 75 , ic chip nov 2005.
mohit is offline
Old 25-11-2005, 08:05 AM   #5 (permalink)
Since I don't have a copy of the said magazine, I would appreciate if others can clarify that this is indeed a rip.
Nemesis is offline
Old 25-11-2005, 01:32 PM   #6 (permalink)
Sorry. I forgot to add source.
Its from Chip.
And real author of the sorce is Brian Paraira..or someone like that.
Computer.
Whats that.
Old 25-11-2005, 01:38 PM   #7 (permalink)
Laptoping
Sourabh's Avatar
LOL! yeah it is indeed a rip. I remember this pretty well cause i read the article in the mag itself at the start of the month, seems the author himself is confused what he wanna say. Another thing, laptops are different from desktops. and if desktops sell @ 10k you cant compare the same with laptop price range. So I feel its like expecting the price to go down and wait for years.
Huh? isnt it just for school kids.
Personally i feel, if we get descent laptops for even 30k in India in the start of 2005. its more than a achievement. If sales increase we can expect them to be more cheaper.
Sourabh is offline
Old 25-11-2005, 04:19 PM   #8 (permalink)
Hi
Can Any give the Website address of hcl sahara etc from which i can see system configuration .
Thanks
minniawochat is offline
Old 25-11-2005, 06:29 PM   #9 (permalink)
kumarmohit's Avatar
X cuse me...
Please refer to TOI classifieds Delhi issue of Sunday November 6, 2005 . There are 2 ads on the page 12 of said newspaer quoting Acer Laptop @ 27499 Rs ( Second column / last ad) and 25999 Rs. (third ad from below/ 3 column) The config says
Celeron 1.4/WiFi
Considering attached expanses on the second of these we still don't think we cross 30,000 mark tho i am not sure bout how much attached expanses shud occur I only take 4000 Rs as an avg, This does not include cost of a licensed OS either only Hardware
kumarmohit is offline
Old 30-12-2005, 03:04 PM   #10 (permalink)
.:deadman:.'s Avatar
Hmmmmmmmmmmmmm.....................
So Mr.Con_tester used multiple ids rite.
Renuka_Verma was the other1 used to praise this article.
HOW DO I KNOW???????
http://www.thinkdigit.com/forum/viewtopic.php?t=35113
I told you that creating so many useless threads will give you trouble.This is y u r banned,i guess.
U r banned 4 2nd time na...
Ashwin Saxena
Con_tester
Way to go.............
Renuka may be next
and finally ur ip may be ban.
.:deadman:. is offline
