Old 23-11-2005, 01:38 PM   #1 (permalink)
Default 20K computer upgrade, Please give ur sugestions
i own a P3 933Mhz, Intel 810e mobo with 256 mb ram, a Samsung 52x cd-Rw and a Pioneer DVD-Rom
So i am planning to upgrade my com to a P4 3.0 GHz, Intel 945GNTLR with GMA 950 , 512mb Ram & a DVD-Writer
so i need to know if this is a good configuration for my 20,000 budget, i am not sure about my Motherboard I herd that GMA 950 (Graphic media Accelerator 950) supposidly has a 224mb or 192mb Video memory so i feel this should be enough for my gaming needs and in case it is not enought can i add another graphic card later (i.e few months later) like a Nvidia Geforce or something like that, suppose i add a 128mb card later will my onboard graphics and the graphics of my added card act combindly and give a 192mb+128mb graphic output?
I have absolutly no idea about graphic cards & how they work so please helpme out,,
and lastly how much do u think i will get if i sell my old com ( i feel i should get around Rs 5000/- )
P.S
I also dunno if i should go in for a Pentium 4 HT or a Pentium D processor which 1 u think is better and future proof
i Dual boot Windows XP SP2 and Ubuntu Linux 5.10 so will the above configuration work without ne trouble
cryptid is offline
Old 23-11-2005, 06:22 PM   #2 (permalink)
i think this should b in hardware troubleshootin.
longing for 7800gtx
hummer is offline
Old 23-11-2005, 10:03 PM   #3 (permalink)
1. this is ok fr non serious weekend gaming , nomore,
2. no the memory ll not b added up , u either can use on board gpu memory or gfx card memory.
3. u seem to b giving too much importance to gfx memory, wha s imp is the genration or series they belong, shader model, open gl version , d3d support version, pixel pipelines, core and memory clock etc.
4. there 2 major gfx chipset manufactures nvidia & ati.
this is the range of cards they offer in pci -e mode fr ur mobo
nvidia- low end-6200, 6600,mid range- 6600gt,6600le,high end-6800, 6800gs, 6800gt, 6800ultra, 7800gt, 7800gtx.
ati- low end- x300, mid- x600, x700, x1300 high- x800, x800xl, x800gt /gto, x850,x1800
i don remember all of ati range but this should b able 2 give u arough idea.
longing for 7800gtx
hummer is offline
Old 23-11-2005, 10:05 PM   #4 (permalink)
if u sell your exisiting mobo+cpu+ram please allow me the honnor to buy them.
**** happens
pradeep_chauhan is offline
Old 23-11-2005, 11:25 PM   #5 (permalink)
gxsaurav
Posts: n/a
Pentium 4 2.66 GHz, Asus P5GL-MX motherboard, 2X512 MB DDR400, Geforce 6600non ultra, & the rest as U need
but still even this PC will go beyond 20k,
the other option is a Sempron system, but it won't be powerful enough, but a lot powerful then your current system
Old 23-11-2005, 11:27 PM   #6 (permalink)
dvd writer, definitly go for the sony DRU series dual layer...i think that is the best out there...
around 4000rs
on ram u should decide whether u want 512, in which case u should get two 256's and use in dual channel...try getting atleast 400mhz...
around 5000rs
mobo, get either the 925xe or the 915...good enough...
8-10k
if u have additional cash...i suggest the 660gt...any brand but BIG...
this would be another 9000...
otherwise any thing below that and u might even get it in your budget...
Nitin Garg...
madman123 is offline
Old 27-11-2005, 09:16 PM   #7 (permalink)
thanx for all the suggestion but please stick to the 20,000 budget i cant spend a penny more than 20,000 so please see that i get a good mobo a 3GHz processor and a DVD writer and also i should be able to play few of the latest games (like NFS Under Ground)
fighting for peace is like ****ing for virginity
cryptid is offline
Old 28-11-2005, 09:14 PM   #8 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
if u dont mind givin up pentium i must say AMD gives a much better value for money and is also much superior in terms of performance !!!
how about AMD athlon64 3200+ or 3500+
on a msi rs480m2-il
tht for is an ideal combination !!!
vijay_7287 is offline
Old 28-11-2005, 10:44 PM   #9 (permalink)
sorry abt exceeding the budget...well graghics...go for a 6200...it costs around 3k and works for weekend gamers
stick with the dvd-rw...so thats another 3k...
2x256 mb ddr 400mhz: 3k
now u have 11k left...go for a 2.8ghz or 3ghz processor, around 5-6k
this leaves u with 5k for a mobo
Nitin Garg...
Old 29-11-2005, 12:22 AM   #10 (permalink)
there is slight prob on the above config . pentium 3.0 wont b less than 7500 i think, so that leaves 2500 fr mobo , too less.
as vijay has said AMD 3200+ MSI482M2=11000. plus the board has on board x300 gpu the best onboard solution.+3k fr dvd rw,+2.5k fr ram(transcend).so u hv lots of money saved. the graphics is much better than gma 950and processor is beter than than intels single core3.0wha do u say dude? go fr amd.
@ vijay- msi 480m2-il has become 482m2-il due 90nm fabrication process.
hummer is offline
Old 29-11-2005, 12:55 AM   #11 (permalink)
ok so far i have been hearing alot bout AMD so i want things to be put in the way i understand them so please help me
Let me know the equivalent OF this configuration in AMD
*Intel 945GNT (GMA 950)
*512MB RAM
*3 GHZ processor
i hope AMD will work out cheaper than Intel so that i can add in a Good graphic card,,, i mainly want my computer to be able to handle multiple task well and also be able to play games( like NFS UG2 and NFS Most Wanted)
And also please give few details on A64X2 4800+ been hearing bout about this it performed very well on many benchmarks check this link for details http://www.overclockers.com.au/artic...?id=384519&P=6
cryptid is offline
Old 29-11-2005, 01:14 AM   #12 (permalink)
Aniruddh's Avatar
AMD:-
3000+ (939 pin),3200+ (939 pin)
ASUS A8NE MOBO(dont have onboard grapix)
Kingston 512 DDR 400 MHz ram
i guess X2 4800+ is not yet available in the indian market.X2 4200+ is available which will come around 26k.
Aniruddh is offline
Old 29-11-2005, 01:55 AM   #13 (permalink)
ok if i buy the intel configuration i gave earlier would it be wise to add in a graphic card so that i can play games at its best quality? and what are best graphic cards available in the range of 6-7K i dont want AGP cards coz 945GNT doesnt have agp slots so please let me know which is the best available cards and also tell me what am i suppose to look for while buying a discret GPU( is it the video memory or something else ?)
cryptid is offline
Old 29-11-2005, 02:30 AM   #14 (permalink)
Aniruddh's Avatar
yea ofcourse it will b a very wise decision to add any decent grapix card.
for 6-7k u can get a 6600nu card.but i'll suggest u to get atleast 6600GT leadtek,XFX,BIG card which will come around 8-9k.it will b more future proof to sum extend and can handle almost evry game which is available in the market 2day.
1.i'll suggest u to go for a AMD rig.
2.if u really wanna go for a Intel platform than better get a 945P chipset instead of the one u want as u will b going for a external gpu so it will perform better and have more features.
Aniruddh is offline
Old 29-11-2005, 12:37 PM   #15 (permalink)
@Aniruddh wats wrong with 945G are there any know issues with it?i choose 945G coz of its onboard grphic subsystem coz i wont be going in for a GPU right now i will wait till Febuary so till them GMA 950 should be able to take care of my gaming needs( i know it wont be as good as a discrete GPU but something is better than nothing)
if u think i am making a mistake then suggest another way out
cryptid is offline
Old 29-11-2005, 01:23 PM   #16 (permalink)
AMD64 3000+ (Venice)----------- 6100
Asus A8N-VM (nForce C51)------ 4200
512*2 MB DDR400 --------------- 4500
LiteOn0 DVD Writer--------------- 3100
Geforce 6200-----------------------3000
Total would be 21900
The mobo is available with Rashi Peripherals
It is based on the 6100 nforce chipset
Education... has produced a vast population able to read but unable to distinguish what is worth reading
AGENT_SMITH is offline
Old 29-11-2005, 05:37 PM   #17 (permalink)
Aniruddh's Avatar
no theres nothing wrong with 945G chipset but as u asked for the gpu so i thought its better for u to go for a 945P chipset as it will perform better than that.u can go for 945G if u dont wanna go for a external gpu this mobo is quite decent.why u dont wanna go for a AMD rig?i dont want to force u but juz wanna kno the reason as AMD is far better than intel at this point of time as its more value for money and has better performance.
Aniruddh is offline
Old 29-11-2005, 11:08 PM   #18 (permalink)
@Aniruddh
ok let me be frank i have this feeling bout AMD that it wont be as good as Intel for some reason and the processor clock speed is also less than that of Penium i guess AMD has the fastest Processor clocked at 2.4 or 2.8 GHZ where as Pentium has 3.7 Ghz processor, the second thing is that i found out 2day that AMD dual core processor cost around 24-30k thats bloody expensive (according to me) where as if i go in for a intel 945 i can later on change the pentium 4 HT processor to pentium D HT (this processor is not out yet might take atleast 7-8 months), at present only pentium celeron D 2.4GHZ processor is available in hyderabad market & i can also buy a ADD2 card for my TV output + TV tuner i guess only intel supports ADD2 cards and AMD dosent
I have nothing against AMD it is just that i have this feeling that it is not very future proof i may be wrong but what can i do this feeling in me wont die
cryptid is offline
Old 30-11-2005, 10:28 AM   #19 (permalink)
dude , don go by ghz ratings a normally clocked amd 64 3200+ clocked at 1.9ghz ll thrash the hell of all celeron processors available including celeron d and is better than all single core processors of pentium till 3.0 ghz.
socket 939 amd processors r at least as future proof as intels.
coz socket 939 is also used by dual core amds.
dual core amds r xpensive but the proce 2 performance is much much better than intels, and 64 solutions r cheaper n btter in terms of processing power , heat production when compared to intels.
some egs http://reviews.zdnet.co.uk/hardware/...33885-4,00.htm
http://www.firingsquad.com/hardware/...ance/page3.asp
http://www.firingsquad.com/hardware/...s/mainhigh.gif
http://www.firingsquad.com/hardware/...es/mainlow.gif
http://www.gen-x-pc.com/p4_AMD_2.htm
hope u change ur mind about amd
hummer is offline
Old 01-12-2005, 01:53 AM   #20 (permalink)
@hummer
thanks for all the info i think i will be change my mind about AMD
mean while will u please write me down a good future proof AMD processor + Mobo + 512 RAM + DVD writer which will work out under 20K
please keep in mind that the computer will be used for multitasking and gaming so please try to sqeez this all under 20K. THANX
cryptid is offline
Old 01-12-2005, 02:14 AM   #21 (permalink)
hey man, if ur going for 512MB RAM + 3 GHz CPU + DVD writer and future PCIe card, then that P3 PSU won't work. U will need atleast 400 W PSU.
Correct me if I'm wrong.
ashnik is offline
Old 01-12-2005, 02:26 AM   #22 (permalink)
Aniruddh's Avatar
yea very true it mite work rite now widout any problems but if u go for a external gpu and few other stuff than u atleast need a 400w psu for sure.if u can than get a psu rite now.
Aniruddh is offline
Old 01-12-2005, 10:57 AM   #23 (permalink)
Originally Posted by cryptid
@hummer
1st procy mobo combinations-
AMD 64 3500+ ASUS a8n-e=15000approx
AMD 64 3200+ MSI rs482m2-il=11500aprox
the good part is the msi mobo has the best onboard gfx (ati x300) , but it doesnot give ne room fr overclocking
u can also go fr AMD 3200+ ASUS A8N-E=13000approx.but no onboard gfx. so ll add a gfx card.
then 512mb ram kingston,transcend=2500
DVD RITER
best is sony=3100
liteon similar price.
but ibought lg. its the cheapest, supports max format(DVD RAM also) but sony liteon outperform it.
400w powersafe=1300.
gfx card-nvidia 6200=3500.
so option 1
AMD 64 3200+
MSI RS482M2-IL
512MB
LG DVDRW-2700rs
powersafe400w
=17500rs approx
option2
amd3200+
asusa8ne
nvidia 6200gfx=21000approx
option 3
amd3500+
msi rs482m2-il
no gfx card=20000 approx.
longing for 7800gtx
hummer is offline
Old 02-12-2005, 02:04 AM   #24 (permalink)
@hummer
how good is ati x300 when compared to GMA950
& and if it is good i think i will go in for the first option u gave since it is coming around 17,500 and please see the first msg and let me know how much should i be getting for my present P3 config if i will get around 5000 Rs then i think i can go in for the second option 21000 wala
and also wat about the PSU think i didnt understand that part!!! and will Linux and work on AMD?? can i do every thing that i do on my Intel processor and mobo??or are they any limitations to it?
cryptid is offline
Old 02-12-2005, 01:09 PM   #25 (permalink)
ati x300 is much better than gma 950.
see, ati also sells x300 as a low end gfx card too which says alot fr the integrated gpu.
i hv seen ur 1st msg. ya u might get 5000 fr ur machine.
look the pt is PSU that u hv in ur p3 machine wont b able 2 take the load of the new system.
so a new smps atleast of 400w is required.
u can do every thing with amd that u did with intel.
even i had a p3 , and then i switched 2 amd athlon and amd 64. i m very satisfied.
this is my last post till 6th dec. i m goin out
hummer is offline
Old 04-12-2005, 06:40 PM   #26 (permalink)
invisible
Posts: n/a
u dont need to update PSU.
im running AMD Athlon 3200+ on my old 200WPSU from the last 5 months with MSI RS480 mobo , Intex 5.1 speakers, Nvidia 6600(nonGT) GPU,1GB RAM,Pixel view TV Tuner card,LG DVD-RW.
No problem till date.
As for your config I tell you one thing.I have updated my system from P4 1.66Ghz to AMD Athlon 3200+.Basically I m very much satisfied with AMD bcoz of its gaming power.But AMD is a bit slow when comes to running multiple aplications like extracting a 500MB winzip file and running a setup and running media player in the background and , all at a time.But u will enjoy its power in Games.
And as for your config I sugest you this:
AMD Athlon 3000+ (Socket939) - Rs 6000
ASUS A8N-VM - Rs 4400
LG DVD Writer - Rs 3000
2 * 512MB Transcend RAM - Rs 4200
Rs - 17600
Check the Specs of the motherboard in this link:
http://www.asus.com/products4.aspx?m...3&l2=15&l3=231
*Integrated Geforce 6 GPU
*1 PCI-16X slot
*SATA II
There is one more mobo MSI-RS480-IL - Rs 4800 u may opt for it also.
ANd if u want to add Graphic card ,add atleat Nvidia 6600 as the onboard graphics are in a sense equalent to Nvidia 6200 with no TV-out.
Old 04-12-2005, 11:31 PM   #27 (permalink)
@invisible
How much does a XFX 6600(Non-GT) 256 mb PCI-e Card cost,
cryptid is offline
Old 05-12-2005, 12:45 AM   #28 (permalink)
invisible
Posts: n/a
Goto CTC ,Secunderabad
and ask the latest rates.
It should be around 6K
Old 06-12-2005, 04:10 PM   #29 (permalink)
I went to CTC yesterday all the shop keepers told me its around 6300 Rs i am so happy to hear that and 6600GT is 9000 Rs,,, do u think i can get them to reduce the rates a little bit i mean around 6100 or 6000
cryptid is offline
Old 06-12-2005, 06:30 PM   #30 (permalink)
invisible
Posts: n/a
So may b u can go for 64bit Sempron as the processor and it will reduce the cost by 3000RS/- if the budget is going >20K
U may get some discount if u buy many peripherals from the same shop.So u may get 6600 @ 6000Rs
bargain a lot
and stick to 6600.
