Old 21-11-2005, 03:39 PM   #1 (permalink)
Default *******Motherboard*******
hey guys
One fine day my loyal Via based p4 motherboard deceived me with a series of blue screen after battling with it for four days i decided to give up . So i went in search of a motherboard that will support my existing NVIDIA riva tnt2 card and all other add on cards which were in my previous motherboard and my processor being a P4 1.5 ghz . so being in chennai there is only one destination for techno needs Ritchie street . So i asked the first dealer for a VIA based P4 motherboard he came up with Two options which i dont remember now . so i told him that ill be back in another fifteen minutesd and went in search of more options . I entered a small shop which shelved lot of pheriperals ,i went in and asked the dealer for a VIA based motherboard . the reply was negative so i asked him to show other motherboards of Intel chipsets . he showed me ASROCK 945 chipset motherboard for rs 2500 when i told him that my processor is a pentium 4 1.5 ghz with a crooked smile came the reply that it doesnot support my processor .
Afetr some exhaustive search i found a big and busy shop . i went in and placed my query ." I have a Intel 845 pesv" box packed came the reply and that too for 1800 rs . but no warranty because intel has stopped support for these motherboards . with no toher option left i went for the INTEL PESV motherboard which had 4 back panel usb 2.0 ports and two front panel usb ports and it had six pci slots and one AGP 4X interface .
So i went for the INTEL 845PESV motherboard for 1800 rs which now sits comfortably inside my cabinet perfectly compatible with verything i had . It even supported my Friends P4 2.8 ghz processor .
So tell me guys . did i make a wise move . or have i become a prey for the dealers plan .
digitizen is offline
Old 21-11-2005, 06:50 PM   #2 (permalink)
is that all the reason u had? blue screens are more often a result of faulty drivers.
neways since u have already bought a new mobo thr's nothing which can be done .....
ur 845PESV should be OK...i hope its doing the job and ur system is running fine?
A64 3200 winnie + 512*2 KVR 2.5-3-3-6 2T + MSI K8N SLI platinum - Creative SB Live! 7.1 + Leadtek PX6600GT 550/1125 + 160 GB Seagate N.C.Q. + 320 GB WD + LG 17" CRT
3Dmark05 - 4008 3Dmark03 - 8,983
Ringwraith is offline
Old 21-11-2005, 07:57 PM   #3 (permalink)
hey i am not a newbie to be scared of blue screens . i am a part time system assembler . the system worked fine with the same drivers for years . i even tried re installing windows several times . and i changed my swapped my ram modules and i even changed the processor . so i came to conclusion that my motherboard is the black sheep . so i changed it .
All i want to know is that did i take a wise decision by buying this motherboard ( a box packed original Intel 845 PESV - no warranty ) for rs 1800 .
Old 21-11-2005, 08:21 PM   #4 (permalink)
u mean u assemble computers? or u deal with assembly code?
anyways....if the mobo was problematic then it was a good decision to buy a box packed intel mobo. I guess u wont be overclocking? in standard conditions intel mobos perform very well/stable indeed!
Old 22-11-2005, 12:47 AM   #5 (permalink)
that was a fair deal. also if u want u can updgrade CPU a bit.
btw , do u play monopoly?
ashnik is offline
Old 22-11-2005, 10:21 AM   #6 (permalink)
no dude i dont play monopoly .
Old 23-11-2005, 09:37 PM   #7 (permalink)
Default wer did u get it frm
hey
can u tell me where exactly did u get this motherboard from.
cause even i am searching for a 845 and i cant find it.
i stay in mumbai
pls tell me as soon as possible
techgizmo is offline
