Old 19-11-2005, 10:15 AM   #1 (permalink)
Default Bios Checksum Error...
When ever i boot my system i get the following error...
Award Bios 1......
BIOS Checksum Error.
Detecting Floppy disk drive...
i am unable to alter my bios settings and boot my system.
Can anybody tell the solution to this error?
deepak_vsoni is offline
Old 19-11-2005, 02:50 PM   #2 (permalink)
Even if you do any changes in BIOS,after restarting it reverts back to default. Am I right? then,
Your comp's battery life has ended. Put a new battery and try again.
This is avery common problem in which the bios reverts back to default and detects all your drives and other h/w settings each time u start ur machine.
rkb2005 is offline
Old 19-11-2005, 05:53 PM   #3 (permalink)
bang bang!
Chirag's Avatar
The main problem is with ur battry. Replace it. Also see that the battry is inserted properly. When i was small i didn't know which side will go where.
Chirag is offline
Old 20-11-2005, 12:30 AM   #4 (permalink)
Replace the cmos battery. Then update bios. This should solve ur computers problem and also make ur computer upgradable*, reliable and stable..
*- if ur computer is not old than 4 yrs
varungupta17 is offline
Old 20-11-2005, 07:30 PM   #5 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Its a co-incidence????????
I faced same problem yesterday!!!
I flashed my Award BIOS and also moded it using some s/w and when I restarted the system, it gave same ERROR:
BIOS checksum ERROR
and asked the system floppy.
What I did attached my HDD to nother comp, coz the backuped file of my BIOS and the flash utility were saved on my HDD.
So i copied all those 2 files into a win 98 bootable floppy and booted my system using that floppy and reflashed my BIOS again.
And VOILLA my system started again working properly.
So I think u hv also flashed ur BIOS?
PS: It contains nothing to do with CMOS battery, coz u recevie CMOS checksum ERROR message at that time not BIOS checksum ERROR :
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
