Old 18-11-2005, 04:59 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Default Altec Lansing ATP3 vs Logitech X-230 vs Sony SRS-D2100
which of these speakers are better? anyone listened to both ATP3 and X-230?
which is recommended? any inputs welcome....
itsmevivek is offline
Old 18-11-2005, 05:15 PM   #2 (permalink)
Aniruddh's Avatar
well dont hav any idea bout Sony SRS-D2100,but yea hav heard both ATP3 and X230 both have good set of speakers.good built quality as well as good sound quality.
Aniruddh is offline
Old 18-11-2005, 10:15 PM   #3 (permalink)
ATP3's have excellent warm highs, great mids and a tight bass, almost too tight for my liking. X230 have looser open ended bass, excellent but bright highs, decent mids. Haven't heard SRS-D2100. I'd recommend X230 over ATP3, unless you're into jazz.
The bottomline being, decide for yourself after listening to all 3. Don't take anyone elses opinions on speakers, not even mine.
PS: As ATP3's have downfiring mids, a good wooden table is a must. DO NOT get these if you intend to keep them on metal or fibre computer desks.
-Keith
Keith Sebastian is offline
Old 18-11-2005, 10:19 PM   #4 (permalink)
the % of time i spend and speakers importance amoung movies, games and music is
Movies -50%
games - 25%
music - 25%
In this case which is better ATP3 or X230?
Old 18-11-2005, 11:15 PM   #5 (permalink)
 Macboy
goobimama's Avatar
Go for the X-230, I agree with Keith, the bass is a bit too tight in the ATP-3. And since 50% is dedicated to movies, you wont want tight bass...my opinion.
I also agree with him that you listen to them and then buy...
I'm like a bird... :)
goobimama is offline
Old 19-11-2005, 12:41 AM   #6 (permalink)
Let the music play.....
djmykey's Avatar
Vivek all ppl look for diff components in spks. I look for bass and hence I have ATP3. But I have seen ppl satisfied with Creative 2 stereo spks too. So go have a demo and then only decide which one u can afford and which one u want.
djmykey is offline
Old 19-11-2005, 11:11 AM   #7 (permalink)
how does music sound in the Logitech X-230, is it clear? Some people tell that it is a bit boomy? is it very much boomy? Toms hardware has rated X-230 highly...
My only concern abt X-230 is how good it is for music... and what is the current price of these models?
Old 19-11-2005, 12:22 PM   #8 (permalink)
gxsaurav
Posts: n/a
i m using logitech X-230 speakers from just over 1 month, & they rock
be it movies, games or Music (indian) it rocks everywhere, I M using it on Audigy 1 though
The bass is not ground breaking, but it still gives a thump, i lowered it as i don't like much bass, go for this, i got it for Rs 3500
Doom 3 & quake 4 never sounded this much good
Old 19-11-2005, 01:59 PM   #9 (permalink)
Location: don't drink and drive you might spill your beer
well, i have nothing new to add but the way you place the speakers at your house is of paramount importance. For the ATP3, the bass is indeed tight & therefore keep setting near minimum. For music lovers(esp. Iron Maiden, Linkin Park and the likes), ATP3 is the best 2.1 speaker.
However, logitech X-230 are the best overall 2.1 speakers at its budget. I have used both and for you I recommend X-230.
pakkasir is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/18923-altec-lansing-atp3-vs-logitech-x-230-vs-sony-srs-d2100.html
Altec Lansing ATP3 vs Logitech X 230 vs Sony SRS D2100 Hardware Troubleshooting Question This thread Refback 21-11-2010 06:14 AM
