Old 16-11-2005, 05:38 PM   #1 (permalink)
Default Cabinet help please!!
Hello Guys can you please help me out getting a ATX tower cabinet, dont need it to be stylelish, just that it shd have good power 440 watts(as i am getting XFX 6600GT card) and can add couple of good cabinet fans, one to the front and the other at rear (leaving the SMPS fan), so that I can keep my cabinet closed rather than what i do now is keep one side open hehe . It shd be sturdy and not vibrate. My budget is 3500/-(less will also do
Thanks for the help!!!
jetboy is offline
Old 17-11-2005, 09:41 AM   #2 (permalink)
THe cheap solution will be i-ball, better roam around lamington road
mangemayur is offline
Old 17-11-2005, 09:49 AM   #3 (permalink)
yogi7272's Avatar
vip 1122 side trasparent cabinet without psu - 1.1 k
and go for powersafe 450 watts psu ..
I am using this cabinet with 3.2 ghz prescott overclocked to 4 ghz and
everything is working fine .. besides its good looks .. it has side mounted tricolour led intake fan .. and provision for 80-92-120 mm one fan slot at back and four 80 mm fan slots at front intake .. I have also made a top outlet between psu and top odd drive ..
also look out for new vip cabinets ... G100 , G200 , G300
yogi7272 is offline
Old 17-11-2005, 02:04 PM   #4 (permalink)
dont go for iBall plz
pick ANY cabinet u like and u can couple it with ur own choice of PSU
a powersafe 450 w would be a good choice as said abov
No Mercy, No Limits.
theraven is offline
Old 17-11-2005, 02:18 PM   #5 (permalink)
Aniruddh's Avatar
yea agree with others dont go for iball its trully pathetic,very low quality cabinet,i m using it but gonna put betta psu like antec or powersafe.
Aniruddh is offline
Old 17-11-2005, 04:14 PM   #6 (permalink)
i disagree.. iball is sturdy.. i have it.. only their PSU is bad.. take a iball crown + a powersafe 450W
I\'M BACK
khandu is offline
Old 17-11-2005, 06:33 PM   #7 (permalink)
Aniruddh's Avatar
eva i hav a iball cabinet,psu is juz cr*p but at the same time the quality of the other stuffs like steel,plastic and other thin used is of very low quality.so i wont suggest a iball cabinet instead go for a betta brand then this.i agree that iball cabinet is one of the best looking but juz that does not mean one shud buy it.
Aniruddh is offline
Old 17-11-2005, 06:58 PM   #8 (permalink)
Thanks for all da help guyz!!. how much for powersafe 450 watts???
jetboy is offline
Old 17-11-2005, 08:17 PM   #9 (permalink)
yogi7272's Avatar
check out the site ... www.kunhar.com for vip cabinets and powersare psu ..
yogi7272 is offline
Old 18-11-2005, 07:00 PM   #10 (permalink)
Hey thanks man!!, that was very helpfull!!!
jetboy is offline
Old 18-11-2005, 08:51 PM   #11 (permalink)
jay4u's Avatar
buy a powersafe psu 400 watts for around 1400 rs mate... it really is good..... and buy cab of your choice but go for sleek, with ample room, fan connection, and hdd support... also see that the hdd, cd/dvd drives do not go too close to mobo and get clutter
happy shopping
Passwords are like underwear... Change them often...
jay4u is offline
Old 18-11-2005, 08:58 PM   #12 (permalink)
jay4u's Avatar
happy shopping
jay4u is offline
Old 19-11-2005, 07:09 PM   #13 (permalink)
yogi7272's Avatar
just seen the new vip cabinets .. G 100 , G 200 , G 300 ..
out of three G100 AND G 200 are side trasparent .. G 300 is not but it do also look very good .. build quality of all three excellent .. have space for 4 odd drives . 2 floppy drives , and 6 hdds , 2 80 mm front inlets at the bottom , 1 side three colour led fan , 2 80 mm outlet vents at the top back ..
also has enough space for all componets and stuff .. and u can also drill a hole at the top for additional outlet vent .. comes with 300 w vip psu which are not enough..
I personally liked the G 100 which also has extra temp display at the front .. prices are yet not available at the dealer in lamington , mumbai
but very god cabinets ..
yogi7272 is offline
Old 19-11-2005, 07:28 PM   #14 (permalink)
 Macboy
goobimama's Avatar
iball cabinet is horrible. But I live in Goa and choice in computers is not what we have here....
I'm like a bird... :)
goobimama is offline
Old 20-11-2005, 07:39 AM   #15 (permalink)
vignesh's Avatar
Zebronics is good mate.Sturdy and looks cool too.
vignesh is offline
Old 20-11-2005, 07:53 AM   #16 (permalink)
siriusb's Avatar
Another vote for zebronics as I have one and like it.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 20-11-2005, 09:06 AM   #17 (permalink)
Commander in Chief
QwertyManiac's Avatar
Another here for zebronics, i have it and now its cool too, it comes with 2 fans with it ...
Harsh J
www.harshj.com
QwertyManiac is offline
